06-23-2011, 02:50 PM | #1 |
Fabricating spark plug wires
Can I use bulk resistance modern style spark plug wire to replace the old solid wire spark plug wires that were in my truck when I got it? Will the original coil work for this?
1946 Ford 1-1/2 ton truck. 6 Cylinder "G" engine. |
06-23-2011, 04:59 PM | #2 |
Re: Fabricating spark plug wires
Sure , we do it all the time with bulk wire either resistance or solid wire etc.......
06-23-2011, 05:04 PM | #3 |
Thanks! That saves me a little cash since I have spool of ignition wire that would be laying around gathering dust otherwise.
06-23-2011, 05:38 PM | #4 |
What are the good points of packard wires vs modern spark plug wire?
I am a believer |
06-23-2011, 05:45 PM | #5 |
I wouldn't use carbon resistance wire, --too much work for it's lifespan, but the wire wound stuff can last a long time.
06-23-2011, 07:30 PM | #6 |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
06-24-2011, 08:53 AM | #7 |
Yup. Worked great.
Brendan, Yes resistance wires were developed for radio static. Not really an issue to me because my truck doesn't have a radio. The reason I went with resistance wires was because I had a box of resistance wire, boots, and ends that were on the shelf of my shop when I bought the place. Saved me some money. |
06-24-2011, 01:54 PM | #8 |
In modern cars ,This resistant wire is a source of engine mis when its bent or old
06-24-2011, 02:58 PM | #9 |
i used the generic speedway kit for flatheads and it worked well it was spiral wound
