Old 05-21-2013, 07:25 PM   #1
johnrooks1
johnrooks1's Avatar
Cool Change out vac wipers to electric on '55 Ford
Anybody have an easy fix for figuring which wiper assembly will work? I don't plan on driving in the rain, but in Ohio you never know.
johnrooks1 is offline   Reply With Quote
Old 05-21-2013, 08:51 PM   #2
phat rat
phat rat's Avatar
Default Re: Change out vac wipers to electric on '55 Ford
You could use RainX it works great. The wipers on my cpe are very small and I use RainX instead of wipers and I've been in some torrential downpours
phat rat is offline   Reply With Quote
Old 05-21-2013, 09:08 PM   #3
parklane
parklane's Avatar
Ya, X2
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 05-21-2013, 09:18 PM   #4
paul2748
paul2748's Avatar
I'd go electric.
Old 05-22-2013, 05:17 AM   #5
carguy01
I think Newport wipers makes a bolt in kit for your car
carguy01 is offline   Reply With Quote
Old 05-22-2013, 07:18 AM   #6
frank long island
frank long island's Avatar
get the newport kit e-z bolt in once you get under the dash also get the intermittent switch and extension so you can use your old knob its worth the investment as long as your car is 12 volts i don't know if they make 6 volts
frank long island is offline   Reply With Quote
Old 05-22-2013, 09:20 AM   #7
phat rat
phat rat's Avatar
I've got Newport on my cpe and they work fine. It's because of the small wiper size that I find RainX to work better. I used to have a 74 Vette, you should've seen the rain fly off the windshield on that with RainX
Old 05-23-2013, 06:31 PM   #8
johnrooks1
johnrooks1's Avatar
I think you might be right phat rat, and besides, it will be a whole lot cheaper too. Thanks guys, very helpful.
Old 05-26-2013, 12:23 AM   #9
junkyardjeff
Before I went to electric wipers in my 55 I used Rain X and it did work good but it wore off on the way home from Florida so it has working wipers now.
junkyardjeff is offline   Reply With Quote
