08-25-2017, 12:35 PM | #1 |
Black gas line problem
Been doing some changes on my 41, new gas tank, fuel pump, rebuilt carb, fuel pressure regulator, fuel gauge, and fuel lines. Had black stuff in carb after running a while getting everything adjusted. Started running rough, checked carb. and found small black stuff in bowl and filter. Went to local hot rod shop for a visit, and to show him my car. He said for me to change all the regular black gas lines to fuel injection lines and there would be no more black crap in carb, this new gas will eat the other regular gas line. Thought I'd pass this along in case you didn't know. Can't get out to work anymore for a few days because of storm. Al
08-25-2017, 01:52 PM | #2 |
Re: Black gas line problem
Robert Shewman has pre-made alcohol resistant fuel lines for early Fords etc.
Robert Shewman 610 933 6637 [email protected] I have had one on my '41 for over 6 years. |
08-25-2017, 09:00 PM | #3 |
Make sure that any fuel lines you buy are compatible with ethanol/gas mix.
08-25-2017, 09:15 PM | #4 |
Why would they sell hose that isn't? That blasted ethanol is EVERYWHERE!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
08-26-2017, 12:38 AM | #5 |
I bought the first gas line a couple of weeks ago, regular black line. Had to ask for fuel injection line at same (O Riley's) parts store, it comes on a green spool and is listed as such. Al
08-26-2017, 07:03 AM | #6 |
08-26-2017, 06:26 PM | #7 |
A few years ago I bought a '60 Lark wagon from Arizona, trailered it back home, drove it into the garage and started to smell gas. The newer rubber hose from the tank to the hard line turned to black goo...the whole line was like chewing gum. Always use good quality fuel injection line (like Gates Barricade).
08-26-2017, 09:54 PM | #8 |
While your at it make sure your pump and carb are compatible too.
08-26-2017, 10:32 PM | #9 |
Guess I'm off to napa again tomorrow to replace all my new connector lines on the woodie.
08-28-2017, 08:19 PM | #10 |
Hose needs to meet spec j30r14t1 for carbs. For high pressure FI the final digit is 2. Walk away from j30r7 or 9. My new in-line filters came with r7. I bought gates barricade from rockauto.
