12-12-2023, 08:47 AM | #1 |
1935 pickup hood
I have the original hood for my 1935 ford pickup. I need installation instructions since I have no idea where to begin. Appears to two halves bolt together..
12-12-2023, 11:50 AM | #2 |
Re: 1935 pickup hood
There should be a chrome piano hinge down the middle that was spot welded to the two top halfs.
The sides are attached with a steel rod that slides into the edges of the tops and sides. The piano hinge has a round point on each end that inserts into a chrome clip on the cowl and a similar one on the grille. These clips are not the same as passenger vehicles. The center hinge is available as are the clips for the cowl and grille. The hood sides also have rubber bumpers at the bottom, where the hood sides meet the inter fender shield. These kits are also available. Hope this helps. |
12-12-2023, 09:32 PM | #3 |
Thank you very much. I probably don’t have anything but the hood.
12-14-2023, 08:09 AM | #4 |
This might be more than what you want to know, but here goes:
The hood sides mate with the hood tops with a continuous piano-type hinge. If you are missing the rod that keeps these together, it's 35 3/8" long and 0.261" diameter. You can purchase a 36" rod in this exact diameter from McMaster Carr for around $6 each plus shipping. The hood tops fit together with an overlapping chromium plated hinge. Each piece of the hinge is spot welded and punch-swaged to the corresponding hood top. This hinge was reproduced in stainless steel so if you are missing it, you might be able to find one. The hood is attached to the cowl and the radiator. The top hinge has an extension formed at each end. The top hinge has an extension formed at each end. Two stainless steel brackets (Part No. 50-16726), one on the radiator rod support and the other on the top lip of the cowl, provide sockets for the hinge extension to hold the hood in place and allows for the hinge to pivot and the hood top to fold upwards. The bracket on the radiator rod support is secured with two No. 12-24 x 9/16″ special binding head screws (Part No. 350240-S2). The bracket on the cowl is held in place with two No. 12-24 x 9/16″ special binding head screws (Part No.350222-S2), No. 12 lock washers, and square nuts (Part No. 34128-S2).
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
12-16-2023, 04:26 PM | #5 | |
12-17-2023, 01:42 PM | #6 |
One option is to drill a series of holes along the hinge and hood top flange and use short flathead screws, lock washers and nuts. This isn't the way the Ford factory made the joint, but it's something you can do. It's really up to what you are comfortable doing. This joint does get a lot of stress, so it's good to have a solid connection.
12-23-2023, 02:58 PM | #7 | |
Couldn’t figure out how to attach pictures to clarify. Appreciate your knowledge. I tried to send you pm but it wasn’t allowed |
12-23-2023, 03:26 PM | #8 |
Jrdaw - the hinge contains the short extensions which fit into the brackets. There's no rod between the two hood tops. I'll get a photo of how these work once I unearth my hood.
12-23-2023, 04:36 PM | #9 |
Thank you very much. The piano hinge I purchased doesn’t have the extensions. I will make some because what you say makes sense. Wish I could send pictures-you’ve been a great help.
12-23-2023, 10:22 PM | #10 |
Should have some shop time tomorrow to take a few images for you.
12-24-2023, 10:24 AM | #11 |
Appreciate your time and effort.
12-24-2023, 04:23 PM | #12 |
The attached picture shows the front part of the hood without the stainless steel mounting bracket (which is normally attached to the radiator). The rusty looking tube is the extension of the center hinge which normally fits inside the mounting bracket. There's a similar extension on the other end of the hinge and another bracket mounted to the cowl. These extensions make the center hinge the almost same length as the hood. Hope this helps.
12-24-2023, 04:47 PM | #13 | |
12-24-2023, 07:02 PM | #14 |
Yes, very helpful, let u know how it works out.
