Old 07-25-2014, 11:14 AM   #1
malloyjp
Default Frozen Distributor 351 Windsor (69)
I've got a 69 mustang mach 1 with a 351 windsor (AC car). I'm trying to set the timing and the distributor (original) cannot be turned at all. I've been spraying penetrating oil (Kroil) at it , tapping it around the base with a big screwdriver, trying to get it to turn with an oil filter wrench. I'm really at a loss here, it's been weeks of no progress. It's not easy to access because the car has AC and the compressor limits my access to get tools in there. Anyone got any advice for me ? The car runs and I tried heating it up via the engine and spraying it with Kroil as it was hot, hoping it would soak in as it cools. No luck yet, hoping to hear some success stories for this situation. Thanks for reading !
malloyjp is offline   Reply With Quote
Old 07-25-2014, 01:33 PM   #2
56 Mercer
56 Mercer's Avatar
Default Re: Frozen Distributor 351 Windsor (69)
Hey malloyjp I just got through the same issue with a 56 Montclair. It took weeks to free it up, and a lot of encouragement from this forum. Here is what worked for me I used a 50/50 mixture of acitone and atf for a lubricant. I dosed the thing morning before work and evening, I tapped on the thing lightly with a hammer after every time I applied lubricant. After a about a week and a half I was able to move it a little with some water pump pliers. So after a few days of lub, tap, and wiggle it finally freed up. This thing had been setting for several years before I started on it.
The best advice I can offer is the same that was repeated to me more than once patience will prevail.
56 Mercer is offline   Reply With Quote
Old 07-25-2014, 02:39 PM   #3
oj
The distr on my 460 has been frozen in place since the ninties I guess (I put new timing chain in it back in the late 80's and it was free then). I've wailed away on it and have come to the conclusion that the timing is deadnuts on, Ford perfect, and I have no cause to improve it. So, there you have it.
oj is offline   Reply With Quote
Old 07-26-2014, 07:23 AM   #4
Ford blue blood
Ford blue blood's Avatar
Pri up on the bottom of the housing and tap (or harder, short of beating) on the boss that hold the vacuum advance diaphram. She will start to turn, lube with penetrating oil or the ATF/Acetone mixture and work back and forth. The rubber seal is the culperate....
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 07-26-2014, 07:37 AM   #5
malloyjp
The acetone/ATF mixture, how did you mix it up and apply it ? Does it matter what kind of ATF is used ? What kind of hammer did you use to tap on it ? Were you tapping the shaft or the top? Did you try other lubricants before acetone / ATF ? Do you think the acetone/ATF did the trick ? Don't have water pump pliers , is that something you used to grip the shaft and turn on ? Thanks again , as you know it's a frustrating situation
Old 07-26-2014, 07:40 AM   #6
malloyjp
Unfortunately my timing is not dead nuts on, it should be at 6 degrees initial timing but its at zero or 1 atdc. I'm very curious to see what improvement ill get when it's timed right. Thanks!
Old 07-26-2014, 06:55 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Acetone/ATF 50/50 mix. Does not matter what kind.
Old 07-26-2014, 07:10 PM   #8
rick55
rick55's Avatar
You need to grip the aluminium body of the distributor. The base is either stuck due to the rubber or the housing has corroded/sweated and has seized in the the hole in the block. Don't force the shaft, this is not the culprit.
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 07-27-2014, 07:23 AM   #9
Ford blue blood
I have used just a standard pry bar against the inake runner and the under side and a large drift punch. With a buddy prying up it has only taken a few wacks with a ball pean on the punch to make it come loose. Never tryed the ATF/Acetone mixture on one of those, just a good penetrating oil.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 07-27-2014, 07:47 AM   #10
LOWRIDER
LOWRIDER's Avatar
I would try prying up on the base like Bill mentioned. Used to use a "lady slipper" bar to pry under the base of the dist. to remove the stuck ones.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 07-28-2014, 08:00 AM   #11
malloyjp
I'm really just wanting to get it to turn freely so I can adjust the timing. I see alot of posts about pulling it up and out. Bear with me as I've not done this before, but do you guys think its better to pull it out. I've never installed a distributor , so was thinking just turning it would be less complicated. Thoughts ?
Old 07-28-2014, 10:46 AM   #12
40cpe
40cpe's Avatar
Have the engine at TDC on #1 cylinder with the rotor pointing at the #1 post on the cap. The distributor might not pull up out of the gears when you free it. If it does come all the way out when you pull on it, the folks here will talk you through reinstallation.
40cpe is offline   Reply With Quote
Old 07-29-2014, 06:36 AM   #13
LOWRIDER
LOWRIDER's Avatar
If you can pull it up just a bit you can get the lubricant to the area where it's needed. Follow 40cpe's advice.
Old 07-30-2014, 08:57 AM   #14
56 Mercer
56 Mercer's Avatar
I had an old oil can one with a long neck, this helped me get to the base of the Distributor where it meets the manifold. There was no measurement the acetone is used to cut the AFT or thin it down to help it get to the problem area.
Does it matter what kind of ATF is used?
Not that I am aware of I already had some in the shop. If I were going out to get some I would not go to much expense.
What kind of hammer did you use to tap on it? Were you tapping the shaft or the top?
I used a piece of wood that I cut to the correct length and width to fit into the space I had open to get to it. I had a vacuum diaphragm that I removed and used the mounting for a good place to set my wooden piece against then tap on it with any hammer that was handy. You don't want to beat on this thing just tap. The point is to just get to move or vibrate a bit so the lub mixture can slip down to the problem area. At that point it can do it's job and the acetone that was used to thin the AFT so it will more easily get in there will evaporate away leaving a oily surface.
yes a bunch.
Do you think the acetone/ATF did the trick?
yes I do only because it is very thin and easy to slip into a tight connection.
The pliers were what I had, once you start to see some movement it won't matter what you use to move it just that you lubricate it and continue to move it to get the lubricant all over the two surfaces that were seized together.
Keep us posted on your progress, I know how frustrating this can be hang in there.
Old 07-30-2014, 08:50 PM   #15
46yblock
46yblock's Avatar
Yes, after weeks sometimes brute force prevails.
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird
46yblock is offline   Reply With Quote
Old 08-02-2014, 08:58 PM   #16
malloyjp
Thanks for the replies guys its much appreciated. I took your advice 56 Mercer and tapped the vacuum diaphragm mounting with a piece of wood in between and after many weeks of trial and error and removing the ac compressor to get better access I think it finally moved a little. I'm using the ATF/acetone mixture now. So my question is once you saw it turn slightly (and I do mean slightly) how did you get it to free up ? Did you get it to the point where you could turn it easily ? By hand ? Thanks !
Old 08-02-2014, 11:59 PM   #17
ford3
sorry to butt in on this post so late, but the guys have given you xlnt advice on how to remove the dist, now to answer your last question, once you have the dist moving back and forth, get something to pry up on the dist, a crow bar a big screw driver or any thing while you turn the dist, prying up will make the dist come up as you turn it, it might help if you get a buddy to lend you a hand
ford3 is offline   Reply With Quote
Old 08-03-2014, 08:12 AM   #18
malloyjp
Is it necessary to pry it up and out ? Or is it feasible that it could start to free up and turn easily ? Seems unlikely considering how stuck it still is but I'm a little nervous about breaking something if I pry it up. I'm just learning so go easy on me. Thx
Old 08-03-2014, 08:18 AM   #19
Ford blue blood
Over the years the many stuck distributors I have encountered just need a little love. That includes prying up and firmly tapping the vacuum advance boss. Steady pressure will not harm nor break the housing, shocking blows will. Steady pressure and firm taps will do the job. Really no other way......
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 08-03-2014, 01:36 PM   #20
ford3
Blue Blood has given you the best and right way to get the dist out, do that and you will be fine
