Old 05-25-2012, 01:47 PM   #1
Bill O'Brien
Question Engine Numbers Question
Star AA1735348 Star is the number on my engine. Can anyone tell me what the numbers mean??
The car is a 1928 with a red steering wheel.
Thank you
Bill O'Brien is offline   Reply With Quote
Old 05-25-2012, 01:56 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Engine Numbers Question
?? The numbers are the serial number of the car/engine...is that what you are asking or did you need to know when you car was made??
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-25-2012, 01:59 PM   #3
Bill O'Brien
Yes, when the car was made and any additional information that can be gleaned from the number.
Thank you very much!!
Old 05-25-2012, 02:01 PM   #4
msmaron
msmaron's Avatar
Go Here: http://www.modelahouse.com/cgi-bin/enumbers/numdate
Model A Engine Number Date Lookup
Engine #1735348 was made on Jun 12, 1929
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-25-2012, 02:13 PM   #5
Bob C
Looks like it is a June 1929 1 1/2 ton truck engine.
Bob
Old 05-25-2012, 02:22 PM   #6
KR500
KR500's Avatar
The fact that there are two A's would distinguish it as a truck engine.
KR500 is offline   Reply With Quote
Old 05-25-2012, 02:44 PM   #7
Charlie Stephens
The same engine was used in the truck as was used in the passenger vehicle. The only significance was that the truck engine (based on the AA serial number) originally had a heavier clutch or 4 speed transmission attached to it when it was shipped to the assembly line.
Charlie Stephens
Old 05-29-2012, 10:25 AM   #8
Bill O'Brien
On my title the VIN is A380248. When I enter that into the Date Lookup it comes out as Aug 30 1928.
Questions - Does it make sense that the VIN Number would correspond with the date the car was manufactured?
I know the VIN is stamped on the frame under the body work. I looked under the gas tank and could not find a date stamped there. Is there any way other than removing the body to verify the VIN on the title?
Old 05-29-2012, 11:29 AM   #9
Bill O'Brien
FYI the car does have the red steering wheel which sure looks original and the 28 headlight lenses ...
Old 05-29-2012, 12:15 PM   #10
frank55a
Per the Restoration Guidelines and Judging Standards YOUR ENGINE A380248 was probably made during the second week of Aug 28. This is when the engine was made not the car assembled. All engines were made and stamped at Dearborn and shipped to the various assembly plants. The assembly date for the vehicle may be as long as three months after the date the engine was produced.
On most 28/29 vehicles the assembly date is stamped on the firewall, drivers side above the split.
The engine you currently have in your Model A is a truck engine and was swapped sometime in your A's past history.
Depending on the condition of the frame the A380248 number should be on the top of the frame on the drivers side between about the rear motor mount and the battery box. The problem is you must lift the body to find this number and apparently many states are requireing the owner to do just that to verify the numbers.
frank55a is offline   Reply With Quote
Old 05-29-2012, 01:14 PM   #11
Bill O'Brien
Talking Re: Engine Numbers Question
I looked for the date on the tank. Drivers side on the side of the car above the split and could not see it.... anyone have a pic of their stamped date?
Thanks for the help fellas!!!
Huh... now that I think about it I looked on the side of the car and not the firewall as stated above..... headed back out to the car.......
Old 05-29-2012, 01:21 PM   #12
Steve Plucker
Bill,
Go to my website and go to Additional Studies...then go to Letters, Numbers and Codes...that may help you.
Pluck
Old 05-29-2012, 01:25 PM   #13
Steve Plucker
Frank,
The date on the tank is, some, if not most of us, belive that that is the date the gas tank was assembled and tested...no the date of the assembly of the car itself.
It is thought that these dates were put on the tank at Dearborn then they were shipped to the various assembly plants and up to 2-3 months before the car was assembled.
See my website as I have a list there with the various senarios using gas tank dates vs. engine stamping dates...they are all over the board.
Pluck
