06-28-2011, 02:00 PM | #21 |
Re: Gas Tank - Restore or Relocate
What size (diameter / threadcount) bolt should I install in the petcock hole so it stays clear during the sealing process??
06-28-2011, 02:20 PM | #22 |
Use a pipe plug. The hole is NPT.
06-28-2011, 02:32 PM | #23 |
06-28-2011, 03:22 PM | #24 |
NPT is a specific thread, used for pipe fittings. You'll get a plug from a plumber or plumbers merchant. When I did my tank I just put the petcock back in with a wad of duct tape stuck over it. A bit of bush engineering, but it worked fine.
04-19-2012, 11:44 AM | #25 |
Update:
I ended up stuffing a rag in the hole and carefully pouring tank sealer into the tank. I did just enough to suround the area around the hole. My tank was beautiful inside and has no rust. 10 months later no leaking at all..... |
