04-22-2015, 11:29 AM | #1 |
Thermostats ?
I recently spoke with a nice Gent at Charlotte Auto Fair who drive's a 40 sedan like he stole it on the turnpike and he has pretty much convinced me to install thermostats in the old girl.
I had some NOS Harrison's on the shelf that have been sitting for while. I brought them up and put them in a pan of water on the stove. Using a meat thermometer they did not open until about 196 degree's even though the box said 171 degree's Would any of you folks trust them or go to NAPA and get some modern type ? |
04-22-2015, 11:31 AM | #2 |
Re: Thermostats ?
Napa and spend the extra and get the premium ones.
04-22-2015, 12:17 PM | #3 |
Re: Thermostats ?
Would you happen to have a NAPA part # ?
04-22-2015, 01:06 PM | #4 |
Re: Thermostats ?
Check the thermometer in a pan of boiling water .Just a thought.
04-22-2015, 01:46 PM | #5 |
Re: Thermostats ?
thm 170 is what i literally put in my truck last night.
04-22-2015, 02:32 PM | #6 |
Re: Thermostats ?
04-22-2015, 02:40 PM | #7 |
Re: Thermostats ?
NAPA or 2nd thermometer.
04-22-2015, 02:43 PM | #8 |
Re: Thermostats ?
I use Stants I got from Summit. They're for a Subaru Justy, open at 180, but most importantly, they flow 25% more coolant than the ones listed for Ford. If you do a search, you'll find old posts referring to them and the part #.
04-22-2015, 04:04 PM | #9 |
Re: Thermostats ?
Sounds like your 40 may well have a 59A engine in it. If so, the Stant 14157 thermostat that was made for the 1990 Subaru Justy fits perfectly and is higher flow than any other that fits your car. Here's why: https://www.fordbarn.com/forum/showthread.php?t=143576
Sold by NAPA as part number THM 111, or O'Reilly part number 2962 which is also Murray part number 4157. All the same stat. The original style thermostat is Ford part number 11A 8575 B and is sold by C&G here: http://cgfordparts.com/ufolder/cgcat...&sp=Search+%23 But is a lower flow than the Stant one. Here are other threads on the topic: https://www.fordbarn.com/forum/showthread.php?t=112889 https://www.fordbarn.com/forum/showthread.php?t=113366 https://www.fordbarn.com/forum/showthread.php?t=113979 P.S. Don't use the rubber gasket that the Stant stat comes with. It just rolls off and jams up. Just take it off and chuck it before installing the stat. Also, to secure the stat from pushing up, turning 90° and not working, secure it with one very thin strand of stranded wire as follows: .
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
04-22-2015, 06:37 PM | #10 |
Re: Thermostats ?
Thank you Henry, I was waiting to get your input. I will head to NAPA tomorrow AM which is closer than any of the other parts stores for me. There has been some talk in the past about drilling a small hole in the plate ? Any one ?
04-22-2015, 06:54 PM | #11 | |
Re: Thermostats ?
I'd call NAPA before driving far to make sure they have the THM 111 in stock before making the trip. Yes. I drilled a 1/6th inch hole in the flange to let the air through when filling.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 04-22-2015 at 07:00 PM. |
04-22-2015, 07:04 PM | #12 |
Re: Thermostats ?
Yes just drill a 1/8" hole of to the side.
"Came too close to dying to stop living now!" |
04-22-2015, 07:09 PM | #13 |
Re: Thermostats ?
Only 3 miles to town and I need to make a dump run which passes by anyway !
04-25-2015, 02:19 PM | #14 |
Re: Thermostats ?
OK, got the thermostats from Federated Auto Parts with a part # 419-180 made in Israel. Problem now to seal. Tightened clamps quite well and added liquid back and leaked like crazy. Was hoping it would seal around the little wires without gasket shellac or some thing that would be a "bear" to pull apart later on if needed. What all you guys using ?
04-25-2015, 02:37 PM | #15 |
Re: Thermostats ?
Authentic thermostats are readily available and fit as designed. Check out eBay or give me a shout.
It is a good idea to test new thermostats. I find that out of ten, maybe one or two does not function properly. Best to figure that out on the stove vs. in the engine.
04-25-2015, 02:55 PM | #16 |
Re: Thermostats ?
Hey Kube, I can still do that as the hoses are off at the moment and I almost did check but in a "pucker" I guess. Probably check tomorrow and thanks, B
04-25-2015, 05:16 PM | #17 | |
Re: Thermostats ?
Also, if you're using the wires as I illustrated, they have to be a very thin strand pulled from a piece of small gauge stranded wire for the hose to seal around them.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 04-25-2015 at 05:22 PM. |
04-25-2015, 05:43 PM | #18 |
Re: Thermostats ?
You can avoid the wire hold-down by pinching the hose a bit with another hose clamp just above the thermostat sealplate.
Jack E/NJ |
04-25-2015, 06:55 PM | #19 |
Re: Thermostats ?
Henry, that may be where I screwed up a little bit. The wire size is .025 I thought it would seal and I'm using the old type clamps like original. I'll mess with it some more. If this is the worst problem a guy can have these days, we're "Golden" right ?
04-25-2015, 11:06 PM | #20 | |
Re: Thermostats ?
Here's a photo of the stranded wire that I pulled one strand out of to secure my thermostats. For many years I just threaded the wire through the stat like this: But, one time I was messing with the thermostats I hit upon the idea to twist on end of the wire around the other and cut it off. More secure. Easier to install. And only two wires to squeeze the hose down on instead of four.
