Old 04-17-2013, 09:25 AM   #1
jkford
Default Block casting numbers
I have what appears to be a 49-53 block. There are two casting numbers on the bellhousing mating flange. In the center there is the number 24. On the right side, it says 34B. Anybody know what year this is?
jkford is offline   Reply With Quote
Old 04-17-2013, 09:51 AM   #2
Barlea
Default Re: Block casting numbers
It is 2013, and 34B is a bra size. 24 is two dozen, but no one really knows what casting numbers mean.... ..B.
Barlea is offline   Reply With Quote
Old 04-17-2013, 10:35 AM   #3
Dale Fairfax
What more do you need to know if you already have it narrowed down to a '49-'53 block? They're all alike so it should be irrelevant what its exact lineage is.
Dale Fairfax is offline   Reply With Quote
Old 04-17-2013, 11:20 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
You may or may not be able to get date of mfg. located on intake surface on passenger side rear.
Old 04-17-2013, 01:21 PM   #5
Barlea
Ford Canada blocks will have "C8BA" cast into the rear until '51, then they are marked "C1BA" to show the changes to the valve train and the different crank to fit up to the Fordomatic. ..B.
Old 04-17-2013, 04:20 PM   #6
52merc
52merc's Avatar
well thats something i never knew different cranks for autos my understanding was no different as the flex plate bolted as normal go figure ??
52merc is offline   Reply With Quote
Old 04-17-2013, 06:29 PM   #7
Barlea
The center hole in the '51 and up crank is much larger to accept the hub of the torque converter. ..B.
Old 04-17-2013, 10:36 PM   #8
Mike in AZ
Mike in AZ's Avatar
welcome to the 'Barn....good luck with your engine....got a car it's going into??....pics??.....Mike
Mike in AZ is offline   Reply With Quote
