03-25-2013, 07:54 PM | #1 |
337 vs 239 engines
Besides displacement what are the differances between the two engines? Thanks Jim
03-25-2013, 08:13 PM | #2 |
Re: 337 vs 239 engines
Completely diff. mtrs. and much heavier. ken ct.
03-25-2013, 08:16 PM | #3 |
250 lbs
03-25-2013, 08:39 PM | #4 |
Harder to find useable and affordable parts for since the seller thinks they're sitting on a gold mine. Some aftermarket speed parts show up on ebay now and then at a premium. Most NOS parts cost twice as much as regular flathead which are expensive in their own right.
Lonnie |
03-25-2013, 08:49 PM | #5 |
bigger all the way around, basically a truck engine and used some in lincolns, about 20 h/p more than a stock ford engine, scarce parts and virtually no speed parts, not worth much, doesnt work well in a ford as a trans plant engine, find a ford or merc engine , it costs cubic dollars to rebuild one
03-25-2013, 08:51 PM | #6 |
03-26-2013, 10:22 AM | #7 |
It's like an 8BA on steroids. The only interchange is the sparkplugs. Yes, it IS heavy but so is a flathead Cadillac, which doesn't seem to attract the negativity that the 8EL/8EQ does. If you're looking for something different but not wanting to set the world (or the pavement) on fire, it could be the answer. There are several street rods running them (You're more likely to find references to them on the H.A.M.B.-along with many of the same negs you'll see here.) I have one in a '53 F-100 and love it. The original advertised H.P, was in the range of 145-154 which was about 30-40 more than a Ford and 25-30 better than a Merc. However, the torque ratings were 265-275 #/' at 2000 vs the '53 Merc at 217 @1700. You can definitely feel that.
Parts are not so impossible to find as most would have you believe. All you have to do is develope some contacts. Speed parts are available from Ken Austin's Rod Shop in Oregon. Most repair/overhaul parts are available from Bob Selzam in Jackson N.J. My local Flathead machinist seems to be able to find almost anything . A homebilt set of tubular headers saves 25-30#. One of the worst aspects is trying to find an engine with a flywheel and clutch. Most '49 lincolns came with B-W T-85/R-11 three speed/overdrive transmissions. Those are user friendly . So are the '48-'51 Ford F-7 & 8 trucks which had big 4 or 5 speed transmissions but could readily be adapted to later style gearboxes. The '50-'51 Lincolns are problematic since they (almost) all had the G.M. 4 speed Hydramatic with an exclusive bell housing and no real flywheel. |
03-26-2013, 10:54 AM | #8 |
239 = one version of the beloved, revered, and coveted Ford flathead
337 = a truck engine that was used in some Lincoln cars |
03-26-2013, 11:53 AM | #9 |
03-26-2013, 12:06 PM | #10 | |
337 This engine was designed for large truck service. When Lincoln could not produce the V12 engine it wanted for the 1949 model year, the 337 motor was adapted for passenger car use. The 337 features a 3.5 in (88.9 mm) bore and a 4.375 in (111.1 mm) stroke. It was introduced in the 1948 two and a half ton and three ton Ford trucks and the 1949 Lincoln passenger cars. It was produced through the 1951 model year. In 1952 it was replaced in the Lincoln passenger cars and Ford three ton trucks with the Lincoln Y-block 317 cu in (5.2 L) overhead-valve V8. The two and a half ton Ford trucks got a 279 cu in (4.6 L) version of the 317 motor. |
03-26-2013, 02:49 PM | #11 | |
Touche'
03-26-2013, 10:57 PM | #12 |
As said, nothing the same, I picked up one last year, I had never heard of them before I got one. I will never do anything with it, but it is unique.
03-29-2013, 05:33 PM | #13 |
Wasn't the 337 Flathead used in the Muntz Jet as well?
Edit: Yup, you can hear it run here https://www.youtube.com/watch?v=WJ2NTpD1N1s |
03-29-2013, 07:56 PM | #14 |
I had a 337 in a towtruck years ago. It was a momster as far a flathead V8 goes. Drank gas awful and smoked so we pulled it out and put a Ford in it.
This clarifies my "boat anchor" statement as today it is resting in about 20 feet of water in the Sacandaga Resevoir holding down a floating pier. |
03-30-2013, 07:49 AM | #15 |
I think the were used in Tanks and military trucks. Lets hear from some WWII mechanics.
03-30-2013, 08:48 AM | #16 |
03-30-2013, 09:07 AM | #17 |
Thanks for clearing that up Dale. Jim.T.
03-30-2013, 10:32 AM | #18 |
I drove one in a 49 F-8 with a 5 speed. Usually ran it on the governer for shifting as that gave me the least trouble. Wish I had bought the truck when it was surplused. $ 900.oo with no rust !
