10-17-2023, 11:50 PM | #1 |
Relocate the condenser
i have a stock 59AB in my 35 sedan, I an thinking about relocating the condenser from the distributor to the coil mounting bracket where it would be easier to change on the road. Anyone see a problem doing this?
Mike |
10-18-2023, 01:29 AM | #2 |
Re: Relocate the condenser
I did just that on my '47 after experiencing ignition problems that I finally traced to the condensor. I don't think the extra foot of wire will slow us down.
10-18-2023, 03:47 AM | #3 |
Makes no difference back at the bus co. rear engine gas coaches coil and condenser were mounted on the side panel (so called fire wall) not on the distributor.
10-18-2023, 07:16 AM | #4 |
If it's away from the intense searing heat of the engine, it'll probably be more stable/last longer too. All electrical & electronic parts are that way.
10-18-2023, 08:13 AM | #5 |
No problem as long as you do it properly. The longer lead will add a small amount of capacitance to the system, but not nearly enough to make a difference. Use a minimum of 14 GA wire (I prefer 12) and make sure the terminals are crimped/soldered securely.
10-18-2023, 12:54 PM | #6 |
10-18-2023, 01:36 PM | #7 |
10-18-2023, 06:26 PM | #8 |
Yeah, that's where mine is too....
but maybe that is wrong? that's why i asked the question. Tubman makes these things, hoping he can elucidate as to why the lead needs to be lengthened when condenser is mounted on the coil.
10-18-2023, 07:59 PM | #9 |
No. It can go onto the coil, just as "Brian" said. It really just has to be in the "coil/points" circuit somewhere. I was just commenting on a general relocating of the condenser away from the distributor, say on the firewall.
10-18-2023, 08:58 PM | #10 |
thanks Denny, You had me worried! lol
