04-12-2015, 06:28 PM | #1 |
33 coupe seat to floor?
Does anybody have pictures of how the seat rails attach to the floor of a 33 5 window coupe?
pics from inside and underneath would be nice. Thanks! Brad
Brad Williamson |
04-12-2015, 08:22 PM | #2 |
Re: 33 coupe seat to floor?
I have a '33 5-window as well, and am using the original seat and tracks. I don't have a photo at the moment and the car isn't here, but there are holes in the floor that have factory brace under the holes. I changed those in mine, but if your floor is decent they should still be there. The tracks attach to those. I may be able to dig up a photo, if someone doesn't post one. There are also three holes near the center of the floor for the adjustment lever.
04-12-2015, 08:49 PM | #3 |
Thanks Bill!
Its a new floor so there are no holes. I'll keep looking to see if I can figure it out. If you can get pics that would be helpful but I appreciate the reply anyway.
Brad Williamson |
04-12-2015, 10:13 PM | #4 |
If you enlarge the photo below you will see the three holes on each side where the lower seat tracks attach (with hex head bolts, nuts and lock washers). The front and rear holes on each side pass through the two side-to-side reinforcements as Bill mentions above. (The floor in the photo is original.)
04-13-2015, 07:57 AM | #5 |
Thanks a lot David!! I appreciate it!
Brad Williamson |
04-13-2015, 08:15 AM | #6 |
04-13-2015, 10:25 AM | #7 |
Awesome!
This is why the Ford Barn is a great place to hang out! Thank you JSeery!
Brad Williamson |
04-13-2015, 10:43 AM | #8 |
I have a set of the tracks that bolt to the floor if you need them
Thee Inland Emperors |
04-13-2015, 12:50 PM | #9 |
Thanks Chris!
Could you take some pictures of what you have? I think I have the two rails but not the center piece for the adjustment mechanism. Pics would help me identify what I have.
Brad Williamson |
04-14-2015, 09:52 AM | #10 | |
Here you go.
04-14-2015, 02:56 PM | #11 |
33 5w stuff
04-14-2015, 04:07 PM | #12 |
I have that little angled piece that goes in the center as well. If anyone needs this stuff, I am using this floor to repair my tudor sedan so I do not need the coupe seat brackets parts
04-14-2015, 08:16 PM | #13 |
Thanks Chris and David! That is what I have!
I appreciate the pics they will help a lot!
Brad Williamson |
10-25-2015, 04:13 PM | #14 |
Hi Guys, i need a complete set of upper and lower 33 / 34 bench seat tracks for both sides. I have the bench, but it was bolted down with modern rails / tracks.
Anything still available ? Regards Randolf |
10-25-2015, 06:03 PM | #15 |
The pics above from Chris are correct for coupe tracks and what you are looking for. They are two pieces.
