08-24-2015, 07:48 AM | #1 |
Spark plug part number for Winfield head.
Anyone have a part number for good plugs to use in an aluminum Winfield head?
Thanks in advance! |
08-24-2015, 10:08 AM | #2 |
Re: Spark plug part number for Winfield head.
08-24-2015, 10:20 AM | #3 |
08-24-2015, 11:44 AM | #4 |
I use NGK bp 6 or 7
08-24-2015, 09:53 PM | #5 |
What bill said same here
08-25-2015, 06:44 AM | #6 |
08-25-2015, 07:51 AM | #7 |
BP6ES or BP6HS
6 is hot than 7 road test for which 1 works best B - 14mm thread dia P - Insulator 6 - heat range E - 3/4" thread reach H -1/2" reach measure the threads in your head S - standard electrode |
08-25-2015, 11:04 AM | #8 |
Most aluminum Winfields had 14mm thread and need a 1/2" reach plug. Before installing the head put a plug in, you want to utilize all the threads in the head but do not want the plug to extend into the chamber. I use Champion H-8 or H-10's. A 3/4" plug will likely extend into the chamber, build up carbon and ruin the threads when the plug is removed.
08-25-2015, 01:12 PM | #9 | |
If you have the luxury of having the head off the motor, you can use the longer plugs with copper "indexing" washers and optimize the installed height. I had one where I had to weld up the existing holes, re-drill and tap on an angle and use 10mm plugs to clear. Problems solved on a not so normal motor. J
As Carroll Smith wrote; All Failures are Human in Origin. |
08-25-2015, 08:37 PM | #10 |
Be sure to use anti-seize on the plug threads.
