Old 09-08-2012, 07:51 PM   #1
albjerryg
Default 1950 Ford
I have a 1950 Ford w/ V-8 and one valve is clicking I have put some Marvin mystrey oil in the oil and gas tank and waiting to see if it stops. If it does not any ideas what it might be? Thanks Jerry
albjerryg is offline   Reply With Quote
Old 09-08-2012, 09:46 PM   #2
Lanny
Lanny's Avatar
Default Re: 1950 Ford
Ahh Jerry, don't use that cheap copycat "Marvin mystrey oil"
Use the real mccoy "Marvel Mystery Oil".
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 09-08-2012, 10:07 PM   #3
tiquer
Yep it`s an exhaust valve stuck open. Remove the spark plug from the offending cylinder and gently (very gently) tap the valve with a punch or screwdriver and most likely it will be running fine.I know some will frown on this fearing that the valve can be bent.It only takes the slightest tap to free the stuck valve . You will hear the valve snap down into place. This usually happens after the motor has not run for a while. Winter storage etc. This may not work if the engine has not been run for 10 years , so common sense should prevail.
tiquer is offline   Reply With Quote
Old 09-08-2012, 10:27 PM   #4
pauldeborr
pauldeborr's Avatar
This is why Flatheads are the greatest....so simple to fix using common sense.
pauldeborr is offline   Reply With Quote
Old 09-09-2012, 07:25 AM   #5
albjerryg
Thanks I will try removing the sparkplug and giving it a gentle tap. Oh I think I put Marvel in it.(Didn't remember how to spell it). thanks Jerry
