Old 08-01-2012, 10:40 AM   #1
35 coupe
35 coupe's Avatar
Default 1950 f1 gas tank fitting
I am redoing a 50 f1, and there was no fitting on the bottom of the tank, only male threads. Is there a shut off, or a compression fitting supposed to be there. THANKS
35 coupe is offline   Reply With Quote
Old 08-01-2012, 11:27 AM   #2
Vic Piano
Vic Piano's Avatar
Default Re: 1950 f1 gas tank fitting
On our '51 F-1 there is a "shut off" valve so you can stop the flow of fuel to the fuel pump.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-01-2012, 01:54 PM   #3
toby
toby's Avatar
See attached pic of the shutoff on my '51.
toby is offline   Reply With Quote
Old 08-01-2012, 02:19 PM   #4
Barry-ct
Barry-ct's Avatar
Part number for the valve is 7HC 9189 and the reducer bushing is 353107-S which reduces the opening from 1/8 pipe to 1/4 inch. You can get the reducer thru Napa or others. Antique auto, Arlington , Texas has 8 of the valves in stock.Call 1-817-275-2381 and ask for Stacey, super nice gentleman.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 08-12-2012, 08:09 PM   #5
49F1Jeff
49F1Jeff's Avatar
I guess that would be a "factory anti-theft device".
Micah 6:8
49F1Jeff is offline   Reply With Quote
Old 08-12-2012, 09:17 PM   #6
pauldeborr
pauldeborr's Avatar
You can stop the flow but in my experience, if you mess with the valve too much then it will start to leak a little.
pauldeborr is offline   Reply With Quote
