Old 04-17-2012, 01:35 PM   #21
wyonorm
Default Re: clean rust out of a gas tank
I use water and pea gravel and then roll it.
wyonorm is offline   Reply With Quote
Old 04-17-2012, 02:50 PM   #22
41ford1
41ford1's Avatar
I used the electrolysis method. The electrolyte I used was water and Arm & Hammer Washing soda. 1/2 cup of soda to the gallon. Filled the tank with this mix. The electode was a 1/4" diam steel rod. The rod was suspended so it didnt touch the tank. Power was a 6amp battery charger. Negative lead to the rod and positive to the tank, power it up for about an hour. Rinsed with water then rinsed with alcohol and let it dry.
41ford1 is offline   Reply With Quote
