09-25-2014, 08:55 AM | #1 |
How do you tell the dfferance in cranks
My brother has flathead crank says comes out of Mercury, anyway to tell if its 4 inch stroke, thanks John
09-25-2014, 09:00 AM | #2 |
Re: How do you tell the dfferance in cranks
09-25-2014, 09:00 AM | #3 |
09-25-2014, 01:37 PM | #4 | |
09-25-2014, 04:23 PM | #5 |
Very easy to use thaks alot, john
09-25-2014, 07:40 PM | #6 |
I simply support a couple of the mains on 2x6's or 2x8's, and roll the crank a half turn, and measure the stroke. Simple, direct, and I don't have to depend on 5/8 clean-out plugs and the like. JMO |
09-25-2014, 07:55 PM | #7 |
So it's just the later model mercs that have the larger crank?
09-25-2014, 08:05 PM | #8 |
49 to 53 in USA and 49 to 54 in Canada
09-25-2014, 08:45 PM | #9 |
I'm going to be getting two 41 mercury motors from a guy. I know from looking at van pelts they make more horse power. Is it just from larger bore. And higher compression heads?
09-25-2014, 09:25 PM | #10 |
Larger bore.
09-25-2014, 09:33 PM | #11 |
09-25-2014, 09:39 PM | #12 |
Van Pelts shows 3.75 stroke. And 3.1875 bore for the 41. The guy was telling me the crank was bigger. I knew some of the mercs were.
09-25-2014, 11:23 PM | #13 | |
41 Ford is 3 1/16" bore x 3 3/4" stroke = 221 cu in. 49-53 Merc is 3 3/16" bore x 4" stroke = 256 cu in. 49-53 Ford is the same bore and stroke as the 41 Merc 42-48 Ford and Merc were the same bore and stroke 3 3/16" x 3 3/4"= 239 cu in. Bill |
09-25-2014, 11:37 PM | #14 |
I see what you were getting at...I thought you were saying Mercs had a larger bore than a 239 Ford...didn't realize you were bring the 221's into the mix.
09-26-2014, 01:13 AM | #15 |
Is there a difference between the Canadian and USA merc engines in 1949?
09-26-2014, 10:02 AM | #16 | |
That 99 block is identified as having a round center water transfer port in the deck . Later blocks had round middle and lower ports Gene Tulsa |
09-26-2014, 11:04 AM | #17 |
Just to clarify, Ford Canada used the CEAC 4" stroke flathead in the '53 Mercury and Monarch, '53 and '54 Meteor (except base model) and '54 Fords (except base model). '54 Mercury and Monarch had the 256 OHV. And no 6 cylinder Fords until '56. ..B.
09-26-2014, 08:20 PM | #18 |
To increase power, there is no substitute for increasing displacement. Increasing stroke is the usual method. Overboring a flathead block often results in ruining it due to sand holes or thin cylinder walls. Over the years, there were lots of claims of having a "Merc crank", but more often it is for bragging rights, or to sell a car. Only pulling a head and measuring is proof, unless the crank is out of the engine.
Thread Tools | |
Display Modes | |
