10-30-2014, 07:32 AM | #1 |
What does a 35-40 frame weigh?
Found a 39 bare frame for sale and I was wondering what the frame would weigh?
I pretty sure. 2 guys can pick one up but wondering about the weight. |
10-30-2014, 08:19 AM | #2 |
Re: What does a 35-40 frame weigh?
I'd estimate between 250 and 300 pounds. My dad and I moved my '36's frame around without too much trouble and I'm just a 135-ppound weakling!
10-30-2014, 08:21 AM | #3 |
My guess of a stripped one with no exhaust approximately 200- 225 lbs
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
10-30-2014, 08:23 AM | #4 |
Without the suspension I would imagine less than 200 pounds...I have moved a bare 39 frame by myself numerous times...two people could carry it like a stretcher with no problem at all. The weight goes up quickly with the springs, front axle, and rear end.
10-30-2014, 12:19 PM | #5 |
I am guessing you are about right. I too move them by myself w/o much effort.
10-30-2014, 07:03 PM | #6 |
10-30-2014, 07:06 PM | #7 |
I move them around by myself, so not that heavy. I would also guess under 200.
