11-26-2014, 10:38 AM | #1 |
filling a new lead acid battery
when filling a new lead acid battery, you should add new acid until the plates are covered, right. Just till you no longer see the plate edges sticking out, right.
11-26-2014, 10:54 AM | #2 |
Re: filling a new lead acid battery
You are correct. See Step 6 here.
http://www.ehow.com/how_5653788_fill...d-battery.html |
11-26-2014, 10:54 AM | #3 |
There are usually directions with a new dry stored battery. Most that I have seen say to cover the plats with about 1/4" of acid. This prevents the plates from being exposed if the battery is tilted or fast starts and stops expose plates.
11-26-2014, 02:27 PM | #4 |
