07-16-2015, 05:41 PM | #1 |
dual exhaust manifold?
Which is the best driver side exhaust manifold for use on a dual exhaust setup
on an 8BA in a 36 coupe Thanks for your help. |
07-16-2015, 06:27 PM | #2 |
Re: dual exhaust manifold?
Jim,
Here is a picture of the typ. truck manifold. This is installed on an F-1 pickup.
Tim Downtown, Ca |
07-16-2015, 08:29 PM | #3 |
Thank you, that is exactly what I need to know. Should clear steering box and water pump also. Jim
07-16-2015, 10:01 PM | #4 |
I just checked and i do not have an extra one. I don't know if there is a different between the early pickup and later (8BA) manifolds but they seem to come up every so often.
Tim Downtown, Ca |
07-17-2015, 04:46 AM | #5 |
The one in the pic looks like a 21A manifold. So should be fairly easy to locate. Used from 42-48 on cars. And 42-47 on pickups, don't know if it was used later?
Martin. |
07-17-2015, 05:48 AM | #6 |
07-17-2015, 06:10 AM | #7 |
Will that work on a '52 Customline???
4 doors are better than no doors! |
07-17-2015, 08:02 PM | #8 |
how about the dipstick tube? will that fit?
07-17-2015, 08:17 PM | #9 |
Scooter, these are 7C-xxxxxx manifolds, virtually the same part as the early ones if I'm not mistaken.
Tim Downtown, Ca |
07-17-2015, 08:39 PM | #10 |
I see CA Victoria showed a stock crossover manifold, but Jim Haskins was asking for a DUAL EXHAUST manifold for the right side, not a crossover. I may be wrong, but I assume he wants to run pipes back from the left AND right side?
Lonnie |
07-17-2015, 09:44 PM | #11 |
Pat Rooney in Ohio makes a beautiful set of left AND right side manifolds for dual exhaust for the 8BA. I installed them on my '50 Convertible and they fit great and look really nice.
I can provide his contact information if you contact me. Ken
https://www.nirgv8.org |
