Old 04-15-2014, 09:18 AM   #21
19Fordy
19Fordy's Avatar
Default Re: Water leaking around oil pan bolt on 59A
Ross, I bet you are correct.
Old 04-15-2014, 01:09 PM   #22
alchemy
alchemy's Avatar
Ah yes. A drip from above, not a seep from within.
alchemy is offline   Reply With Quote
Old 04-15-2014, 04:37 PM   #23
42merc
42merc's Avatar
Everyone from the 3rd post on has said that.
42merc is offline   Reply With Quote
Old 04-15-2014, 04:47 PM   #24
Mart
Mart's Avatar
Ahem. 2nd post, first reply.
Old 04-16-2014, 08:02 AM   #25
alchemy
alchemy's Avatar
You are right. I was picturing your first reply as meaning it came from above on the engine (hence my post after your's about leaky studs and gaskets). But now the idea that it dripped from the heater hoses seems even more probable to me. Sorry to not grasp your concept on the first go-round.
Old 04-16-2014, 08:45 AM   #26
Mike51Merc
Mike51Merc's Avatar
Water (and oil) loves to travel before it gathers enough to drip. You'd be surprised how far from the source a drip can emerge, even defying gravity. An don't forget how hard it is to dry off antifreeze spills. I use my air gun to blow it dry or at least blow it away.
Look at the wetness along the mating surfaces in the picture. It came from elsewhere.
Mike51Merc is offline   Reply With Quote
Old 04-16-2014, 06:18 PM   #27
Barlea
I may be old, but I can still recall the wetness along the mating surfaces.....
Barlea is offline   Reply With Quote
Old 04-17-2014, 01:31 PM   #28
Old Henry
Old Henry's Avatar
Mystery solved. Leak found. (Ross F-1 was right on.)
I was still getting water on the floor under that oil pan bolt. So, I removed the floor and that platform above the starter was loaded with water/anti-freeze.
But, it didn't seem to have come from that oil pan bolt as I had originally supposed. So, I wiped and blew everything off and started the engine and watched. In no time the water was accumulating there again but did not seem to be coming from that bolt. But, I could see an itsy bitsy trickle coming down the bell housing. So, up to the engine compartment I went searching again on the intake manifold for any leakage from the radiator hose I just replaced. Nothing. Then I saw this drip.
Coming from the end of the heater hose clamp bolt. In fact, you can see that the hose is almost pulled off of the heater pipe. That will have to be shoved back on, the clamp tightened, and we should be good to go for the road trip tomorrow..
Thanks for all of your help. It was, indeed, something from above. I just had to find it.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 04-17-2014, 02:43 PM   #29
Russ/40
Russ/40's Avatar
Cool shot catching the drip like that.
Old 04-17-2014, 03:23 PM   #30
Mart
Mart's Avatar
While you're there you can get a bit of grease on that throttle ball and oil the throttle pedal pivot. Preventative maintenance is the key.
It looks like the hose could do with being a bit longer, hard to tell from the photo.
Glad you found the source of the drip.
Mart.
Old 04-17-2014, 03:29 PM   #31
Old Henry
Old Henry's Avatar
Mart.
The hose was actually drooping under the throttle rod when it should have been going straight above it effectively shortening it. That's why it was pulling off, plus the poorly designed original stock style hose clamps that, once the two ends of the clamp are screwed clear together, there is no more tightening and that one was all the way tight but not tight enough. I straightened the hose to run above the throttle rod which pushed it onto the heater pipe as it was and put modern spiral screw clamps on and so far it's holding the pressurized water fine.
Old 04-17-2014, 03:33 PM   #32
ford38v8
ford38v8's Avatar
Can't see the firewall hole in the picture, but it should be the same diameter as the heater hose. The correct installation has the hose going through the firewall with the clamp on the outside. This is per Ford specification due to vibration caused abrasion on the heater pipe, as well as the very thing that caused your leak.
Alan
Old 04-17-2014, 03:36 PM   #33
Old Henry
Old Henry's Avatar
I have the fresh air heater with the coil right against the firewall so the hose can't go through the firewall. Maybe into it a bit but not through it. It may well be a better approach for the next time I take it apart.
Old 04-17-2014, 04:07 PM   #34
alchemy
alchemy's Avatar
Where's your chatter rod for the right side?
Old 04-17-2014, 06:06 PM   #35
Old Henry
Old Henry's Avatar
No chatter rods on my '47 sedan. After Ford realized that they did little if anything to reduce clutch chatter they discontinued them some time prior to '47.
Old 04-17-2014, 08:49 PM   #36
Lawson Cox
Lawson Cox's Avatar
Glad you found the source of your problem, professor. Now if I could be as lucky with finding out what is causing my backfire problem.
Old 04-17-2014, 11:24 PM   #37
ford38v8
ford38v8's Avatar
"Into it a bit"?
Your insulation on the inside of the firewall is half an inch thick. That's all you need.
Alan
Old 04-18-2014, 10:34 AM   #38
40cpe
40cpe's Avatar
maybe I missed a post with an update, but how is the clutch chatter and the vibration?
Old 04-18-2014, 10:59 AM   #39
37 Coupe
37 Coupe's Avatar
Where did you get your information on this? Ford never identified the rods as "anti-chatter" but as engine radius rods.Their purpose was to keep the engine from moving forward and allowing the fan blade to chew into the radiator. With the same rear axle and torque tube design through 1948 I imagine the need was still there and it was the area Ford engineers found they could "economize" on like the steering /ignition switch coincedental lock.Still had thieves but it was on the list to cut cost.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 04-18-2014, 12:04 PM   #40
V8COOPMAN
V8COOPMAN's Avatar
I can't verify the accuracy of the info, but the post below by columbiA (taken from a search in the archives) shows 11A-6044s continuing to be used on Canadian-built RHD cars thru '47 & '48 production, FWIW. DD
01-12-2013, 12:12 AM #8 columbiA
Re: Motor Stay Rods (anti-chatter rods)
Anti-chatter rods 11A 6044 is used on 41-42 pass cars & 46-48 RHD cars.The 46 48 LHD cars did not use them.-From Ford of Canada 28-49 fast moving parts catalog.
Click Links Below __
T5 W/TORQUE TUBE
