04-16-2013, 08:40 PM | #1 |
Aluminum Z Head Saver
I recently acquired a 1915 roadster with an aluminum Z head. I was told that these type of heads tend to deteriorate if you do not use a "head saver". I got the pictured head saver part from one of the parts vendors. Can this part be installed in the water outlet as pictured below? Thanks for your feedback.
04-16-2013, 09:17 PM | #2 |
Re: Aluminum Z Head Saver
Yes, you can do that, but be sure to add a little silicone around the wire, you can't squeeze the rad tube enough to eliminate a leak if installed this way. I just hang mine on the overflow tube in the neck of the rad, in a couple of years they're gone and I hang another.
04-16-2013, 09:36 PM | #3 |
