01-14-2016, 11:37 PM | #1 |
Evapo-Rust vs. Rustoleum Rust Dissolver
Just did this experiment de-rusting part of two very rusted tin snips. One with Evapo-Rust, the other with the relatively new Rustoleum Rust Dissolver. I was wondering what the difference might be since the Rustoleum is cheaper. I wondered if it did just as well as the more expensive Evapo-Rust. Left is the one in Evapo-Rust. Right is the one in Rustoleum.
They both removed the rust equally well. But, the Rustoleum seemed to keep "sizzling" after the job was done, almost like it had some kind of acid in it, and left the metal coated with some black coating like it was carbon coated, whereas, as is shown in the photo, the Evapo-Rust cleaned off the rust but left the metal clean and metal looking if not actually shiny. At Walmart, a quart of Evapo-Rust is $9.36 whereas the Rustoleum is $7.82 for the same amount. I'll stick with the Evapo-Rust myself. I think it's worth the extra money.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
01-15-2016, 12:24 AM | #2 |
Re: Evapo-Rust vs. Rustoleum Rust Dissolver
Only the rusty picture Henry. Gary
I am usually relatively happy------Gary |
01-15-2016, 12:55 AM | #3 |
01-15-2016, 01:16 AM | #4 |
Check the safety data sheet for Rustoleum its an acid.
01-15-2016, 03:30 AM | #5 |
You were expecting two pictures?
The one picture shows the two tools side by side, with the top part of the tool dipped in the de-ruster and the bottom part of the tool still showing how rusty they used to be. Read the copy again and it will make sense. |
01-15-2016, 06:47 AM | #6 |
01-15-2016, 07:33 AM | #7 |
Here you go.
http://www.rustoleum.com/MSDS/ENGLISH/286749.pdf |
01-15-2016, 09:16 AM | #8 | |
01-15-2016, 10:28 AM | #9 | |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 01-15-2016 at 10:30 PM. |
01-15-2016, 10:58 AM | #10 |
There are others available on the internet that aren't sold in chain stores. Some of the brands are available in concentrated form and then dilute down for use, which winds up being cheaper than a gallon of Evapo-Rust.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
01-15-2016, 11:30 AM | #11 |
Thank you Henry for all the research you do & post.
I certainly appreciate it. Jim |
01-15-2016, 12:28 PM | #12 |
I'm in Florida for the winter, and the only thing close is a Home Depot. They carry something called "Metal Restore". It seems to be about equal in performance and price to "Evapo-rust". I use it on my bicycle parts that rust at a drop of the hat when you're close to the ocean, and it works well. I think a combination of feed molasses and water also works by "chellation".
01-15-2016, 12:32 PM | #13 |
Does that mean I can use phosphoric acid as rust remover? I have a big drum of it left over from etching a concrete floor pre painting.
01-15-2016, 12:35 PM | #14 |
Yep Tubman is right about molasses same aproach as evaporust.
What your after is stripping the oxygene out of the ironoxide(yes its very simplified) Instead of etching everything away and adding an inhitor to keep the acid from eating the bare metal. |
01-15-2016, 12:37 PM | #15 | |
Adding an inhibitor and it would work even better. |
01-15-2016, 12:56 PM | #16 |
After all the experience I have had with the various rust-removal methods, I would put using acid at the bottom of the list. Last week, I forgot that I put a 2GC base in "Metal-Restore" for 4 days and there was no problem; I couldn't get away with that an acid-based system.
01-15-2016, 01:43 PM | #17 |
Old Henry, if you are still in the experimental mood, try citric acid powder. A warmed up 10% solution is supposed to be the ticket. Might be something I'll try myself down the road for items that shouldn't be blasted. If you can't find any locally, I see it is readily available on fleabay- 10 lbs for 23.99 shipped. Works by chelation, or so it is said.
I dig coal, which provides motivation for EVs. |
01-15-2016, 02:06 PM | #18 |
Citric acid is etching the metal so dont forget stuff in there or they will dissapear...just slower since its a mild acid.
01-15-2016, 07:55 PM | #19 | |
TIA |
01-15-2016, 08:05 PM | #20 | |
