Old 01-02-2012, 01:30 PM   #1
bill h
Default rear trans mount
Is there special hardware for the rear trans mount (rear trans bearing support ) to the trans mount that is bolted to the frame. The rear trans bearing support for the holes is about a 1/2 inch thick and is slotted. thanks
bill h is offline   Reply With Quote
Old 01-02-2012, 02:01 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: rear trans mount
Bill, what year/model are we talking about here?
John
Old 01-02-2012, 02:13 PM   #3
01aford
01aford's Avatar
Depending on the year of your car I have the rear mount for sale.
01aford is offline   Reply With Quote
Old 01-02-2012, 02:30 PM   #4
bill h
Sorry Its a 1947 Ford
Old 01-02-2012, 05:17 PM   #5
Old Henry
Old Henry's Avatar
I'm not sure what part you are asking about but here are some parts for mounting the back of the transmission to the frame. Maybe looking at them will help you.
http://macsautoparts.com/early-v8-re...0R3CHL1073189/
http://macsautoparts.com/early-v8-tr...0R3CHL1076613/
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 01-02-2012, 05:30 PM   #6
01aford
01aford's Avatar
yes it part number21A-7085. 8 inch between the mounting holes. Ive got it. PM me if you want photos.
Old 01-02-2012, 05:43 PM   #7
Old Henry
Old Henry's Avatar
Here's the diagram of all of the rear engine mount parts. Which part are you wanting?
Old 01-02-2012, 07:29 PM   #8
bill h
Thanks for you help. Thanks Old Henry Thats the picture i needed. Bill
Old 01-02-2012, 08:00 PM   #9
Old Henry
Old Henry's Avatar
That diagram came out of the "Green Bible." If you want more detailed description and part numbers give me the number from the diagram and I will give you the rest of the part number and description from the book.
