Old 11-04-2016, 01:26 PM   #1
Mike/Nebraska
Default doors
I have a 26-27 T coupe body with doors but the passengers side has rot along the back of the window and a little on the top of the window at the rear corner where it meets the other rusty section. What door could I use to piece in the rusty portions? Will a Model A door work and line up with the T door?
Mike/Nebraska is offline   Reply With Quote
Old 11-04-2016, 03:44 PM   #2
redmodelt
redmodelt's Avatar
Default Re: doors
This is in my Op but this is one of those cases that unless you can find a door that was so messed up that that was the only bits that could be saved I would not mess with cutting up another door to get the repair pieces. The 26-27 and 28-29 PU doors are similar but are getting hard to find and when you are not cheap.
Old 11-04-2016, 04:33 PM   #3
Mike/Nebraska
Default Re: doors
I don't plan on cutting up a good door, but I've seen a lot of doors that were smashed but had good window areas. I know 28-29 pickup doors are pricey and hard to find bit maybe another doo0rn top woud be the same.
Old 12-23-2016, 01:32 AM   #4
southfork
southfork's Avatar
Default Re: doors
Just what are the differences between the 26-27 coupe doors and the 28-29 Pickup doors? Except for maybe the hinges, aren't they interchangeable?
southfork is offline   Reply With Quote
