Old 01-22-2011, 01:19 PM   #1
Mr 42
Mr 42's Avatar
Default Bolts instead of Stud's?
Is it OK to use bolts instead of Studs on 59AB to mount Main bearing caps. I think the 8BA uses Bolts, and somehow the studs have been lost over the years, And here in Metricland its hard to get the nonmetric studs.
And i cant find them at Mac's
Mr 42 is offline   Reply With Quote
Old 01-22-2011, 07:26 PM   #2
Mart
Mart's Avatar
Default Re: Bolts instead of Stud's?
Lars, I just salvaged the studs out of a 21 stud motor, if they are the same as what you need, they're yours for the cost of postage. Have the nuts too.
I can measure them if that would help.
Mart.
Old 01-22-2011, 09:12 PM   #3
Karl Wolf
Karl Wolf's Avatar
I'm using bolts on main caps on a 59AB I'm in the middle of now, cannot see a reason not to... Karl
Karl Wolf is offline   Reply With Quote
Old 01-22-2011, 09:56 PM   #4
Brian
Brian's Avatar
Canadian C69A engines [pre 8BA series] used bolts on their mains. Brian
Old 01-22-2011, 11:16 PM   #5
59ab
I once owned a nos 59 ab block that had bolts instead of studs.
59ab is offline   Reply With Quote
Old 03-18-2011, 11:03 AM   #6
Ralph Moore
Ralph Moore's Avatar
On that same note, I was wondering about using Studs instead of bolts for bolting down heads on an 8BA block? I'm using a set of Offenhauser alum heads, so I'm not even sure if the stock bolts/studs will work.
Ralph Moore is offline   Reply With Quote
Old 03-18-2011, 11:39 AM   #7
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I use grade 8 head bolts on about all my 59 engine. I bye them at a fastenal place, there kind of gold color. The only differance is they have 5/8 heads. I use grade 8 flat washer. I've never used bolts on main caps but cain't see why not. Walt PS, you can bye chrome acorn nut covers for the 5/8 head bolts.
Old 03-18-2011, 02:30 PM   #8
Ralph Moore
Walt,
On choosing the bolts, how much thread depth do you allow for in the block?
Thanks,
Ralph
Old 03-18-2011, 03:15 PM   #9
Ol' Ron
Ol' Ron's Avatar
The rule of thumb is a Diameter ans a half the main bolts are 1/2 -13 so that works out to about 9 threads min. Check for bottoming use a flat washer not a lock washer torque to 95/ ft/lbs. I don't use studs for heads either, use a grad 5 bolt with a min fof 7 threads and torque to 45 ft/lbs. I'm not saying this is the only way to do this, just the way I did it for years. Also re torque head bolts afte at least 3 heat cycles
Old 03-19-2011, 09:18 AM   #10
Ralph Moore
Thanks Ron,
Do I need to put any sealer on the threads? Especially the ones that go into the water jacket?
Old 03-19-2011, 10:05 AM   #11
Ronnie
Ronnie's Avatar
Use permatex aviation sealer on the bolts works very well and doesn't harden also works as a thread lube when torquing.
Ronnie
Ronnie is offline   Reply With Quote
Old 03-19-2011, 11:48 AM   #12
Ol' Ron
Ol' Ron's Avatar
Yup!
Old 03-19-2011, 12:52 PM   #13
Roger/Sacramento
Roger/Sacramento's Avatar
I bought ARP (pricey) studs and nuts for my aluminum heads at the recommendation of Red Hamilton (Reds Headers). Guess I overshot it.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 03-19-2011, 01:48 PM   #14
296 V8
I put ARP bolts in the mains of my 8ba....dont know if there the same for 59's
296 V8 is offline   Reply With Quote
Old 03-19-2011, 02:17 PM   #15
OLD...BILL
OLD...BILL's Avatar
YES us bolts, H & H flathead, in southern Calif, made the main center strap for my rebuild with bolts, A good sorce for bolts, and all flathead stuff. AT>> FLATHEADS-FOREVER.COM ... OR 818-248-2347.... OLD....BILL
OLD...BILL is offline   Reply With Quote
Old 03-20-2011, 06:41 PM   #16
Ralph Moore
Is this it? Just so happened I had a couple cans of this someone gave me.
Old 03-20-2011, 07:30 PM   #17
Ronnie
Ronnie's Avatar
Yup that's the good stuff it works
Ronnie
Old 03-20-2011, 10:26 PM   #18
Ol' Ron
Ol' Ron's Avatar
If you go to an industrial supply shop you can buy grad 8 bolts for a fraction of what AARP sells them for, I bought 16 3/8 NF and 6 1/2 nf nuts and 6 hardened steel washers for 6 dollars.
