Old 11-17-2014, 09:02 PM   #1
50mercfan
50mercfan's Avatar
Default Lets talk about Y-Block vapor lock, shall we?
I've seen a few post on what seems to be a common problem with Y-Blocks. Vapor lock. Why? why would one engine be more prone than others? It doesn't make sense to me. Heat is heat and an engine is an engine, Right? I recently bought a 55 customline with a 272. It's obvious that the previous owner was having problems.
I recognized all the tell tale problems as soon as he opened the hood, electric fuel pump, fuel pressure regulator, heat wrapped exhaust, foil wrap on the fuel lines. When I asked, "vapor locking, huh?" he said "not since i've had it" . OK.
I've made some changes recently. I put dual exhaust manifolds on it, getting rid of the cross over exhaust pipe that runs over the fuel pump and in front of the carburetor. I'm wanting to ditch the electric pump and put the manual pump back on.
I'm putting before and after pics up for reference. Whats your experience?
50mercfan is offline   Reply With Quote
Old 11-17-2014, 09:15 PM   #2
paul2748
paul2748's Avatar
Default Re: Lets talk about Y-Block vapor lock, shall we?
I have a 56 Bird in which I experienced some vapor lock but only under very limited conditions. Going up very steep mountains (actually mountain chains in the west coast) on a very hot day. Never stalled but it was touch and go for a while. Popped the hood to get better air flow and the problem pretty much disappeared.
Oddly enough, it was after I replaced the fuel lines with stock lines during restoration.
I had made the same trip about 5 years earlier and went almost the same route and didn't have any problem..
Old 11-17-2014, 09:47 PM   #3
Hot Rod Reverend
Hot Rod Reverend's Avatar
Stay away from gasoline that has ethanol in it and you will be fine
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 11-17-2014, 10:12 PM   #4
miker98038
miker98038's Avatar
I'll go with HRR. Ethanol, stop and go traffic, lower fuel pressure for older carbs, all contribute to vapor lock.
miker98038 is offline   Reply With Quote
Old 11-18-2014, 09:39 AM   #5
Ole Don
Ole Don's Avatar
I too drive a 55. Mine had dual exhaust from the factory, so a lot of heat went out the back. I have never had a vapor lock problem. My advice is to use two fuel pumps. I use the electric as a booster, when the car hasn't been driven in more than a few days, I run the electric to prime the system. My electric pump is in the back near the tank. Many of us dont have a choice on ethanol laced fuel. If we buy fuel, we get up to 10 % ethanol.
Ole Don is offline   Reply With Quote
Old 11-18-2014, 01:13 PM   #6
dmsfrr
dmsfrr's Avatar
Some folks blame it on the metal fuel line that runs over the front & top of the engine, saying it holds more heat and boils the fuel in that line between the pump and the carb.
If/when it happens to me my first (cheap) try at a fix would be to change that steel fuel line to a rubber one.
Old 11-18-2014, 01:24 PM   #7
bjmayberry2
bjmayberry2's Avatar
Years ago MANY cars/engines vapor locked. It was not uncommon to open a hood and see cloths pins on the steel fuel lines. Some hoods trapped engine heat which compounded vapor lock in stop and go traffic. Many engines as late as the 70s would boil the carb dry after running a long trip and shutting the engine off. We use to remove the steel fuel lines and add fiber spacers under the carb. Seemed to help and was relatively cheap.
BJ Mayberry
53-56 F100s & Panel
Old Guy with Trucks
bjmayberry2 is offline   Reply With Quote
Old 11-18-2014, 03:47 PM   #8
Daves55Sedan
Daves55Sedan's Avatar
Older Fords had a vented gas tank. You should check to see if there is any obstruction to free venting by disconnecting the vent tubing on the driver side of the gas tank. Blow compressed air into that end of the line and see if the air comes out of the tubing where it exits adjacent to the gas tank filler cap. Rod the line out if necessary.
Old 11-18-2014, 06:02 PM   #9
dmsfrr
dmsfrr's Avatar
I remember clothes pins on fuel lines too.
Ford OEM carburetor anti-heat spacer, 1/2inch thick phenolic plastic... approx. 1957
Old 11-18-2014, 07:39 PM   #10
CrownVic55
CrownVic55's Avatar
Ole Don,
Go to www. pure-gas.org for a list of ethanol free gas stations in the US. Something like 80 are listed for Illinois.
Ben Hess
CrownVic55 is offline   Reply With Quote
Old 11-18-2014, 08:37 PM   #11
50mercfan
50mercfan's Avatar
Thats what i was thinking too. I didn't know if the manual pump would pull through the electric pump and pressure regulator.
Old 11-18-2014, 08:38 PM   #12
50mercfan
50mercfan's Avatar
Originally Posted by CrownVic55 View Post
Ole Don,
Ben Hess
thanks for the heads up, i'll check that out too.
Old 11-18-2014, 08:40 PM   #13
50mercfan
50mercfan's Avatar
good tip.
Old 11-19-2014, 11:37 AM   #14
bobss396
bobss396's Avatar
I've been making my own phenolic carb spacers for years, seem to work pretty well. I had a stock car years back that was vapor locking, the clothes pin trick worked on that.
bobss396 is offline   Reply With Quote
Old 11-20-2014, 05:18 AM   #15
rustynutz
Would one of you knowledgeable gentlemen please explain the clothes pin theory to me. I've never heard of this trick. Thanks
rustynutz is offline   Reply With Quote
Old 11-20-2014, 06:32 AM   #16
Blackpearleb434
Blackpearleb434's Avatar
I would suggest that the cloths pegs act as a heat sink to disperse the heat away from the line
Blackpearleb434 is offline   Reply With Quote
Old 11-20-2014, 12:33 PM   #17
dmsfrr
dmsfrr's Avatar
Here's my 'I don't really have a clue' guess.
They amplify/reduce(?) the vibration of the fuel line and this helps break up/prevent the bubbles in overheated fuel which create a blockage, and return the fuel to a liquid.
Old 11-21-2014, 08:40 PM   #18
paul2748
paul2748's Avatar
I fail to see why clothespins would work since wood is a poor conductor of heat.
Old 11-22-2014, 11:04 AM   #19
dmsfrr
dmsfrr's Avatar
I agree. Maybe someone should create a new accessory, snap on aluminum cooling fins.
Old 11-22-2014, 12:40 PM   #20
scicala
scicala's Avatar
My guess would be that the clothes pins keep the fuel line from getting hot, and not that they dissipate the heat from the fuel line.
scicala is offline   Reply With Quote
