Old 06-17-2017, 08:02 PM   #1
Topsterguy
Topsterguy's Avatar
Default speedo conversion for electronic T-5 trans
I have a '93 T-5 out of an S-10 in my '36 coupe, and it has the electronic speedo. Is there a conversion for changing this to a manual sender for the speedo cable? I also have aftermarket gauges and speedo. Thanks!
Topsterguy is offline   Reply With Quote
Old 06-17-2017, 08:19 PM   #2
JSeery
JSeery's Avatar
Default Re: speedo conversion for electronic T-5 trans
Yes there are, but they are very expensive.
Update: well looks like there might be some cheaper options now. Dakota digital has a converter that might work. Give them a call.
http://www.dakotadigital.com/index.c...roduct_id=126/
Old 06-17-2017, 08:25 PM   #3
Ross F-1
Ross F-1's Avatar
Did your new trans have a pulsing unit driven by a worm gear, in place of the mechanical cable drive? Some of those simply unplug and can be replaced by a mechanical drive. Others can't, but can be retrofitted. Here's how: http://www.inliners.org/Jack/T5tech.html
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-17-2017, 08:42 PM   #4
Topsterguy
Topsterguy's Avatar
Great! Thanks for the info !
Old 06-17-2017, 11:25 PM   #5
38bill
38bill's Avatar
If you already have aftermarket gauges and speedo wouldn't it be easy and cheaper just to swap out the speedo for an electric one?
38bill is offline   Reply With Quote
Old 06-18-2017, 12:03 AM   #6
Topsterguy
Topsterguy's Avatar
Yeah, never thought of it at the time but something to look into, thanks. 'course there's always the GPS !
Old 06-18-2017, 07:17 AM   #7
JSeery
JSeery's Avatar
Sorry I missed you were wanting a converter to a cable in the original post! The coverters are in the same price range or less than a new speedometer. Cable X is one brand.
http://www.hotrod.com/articles/hppp-...ter-converter/
http://www.abbott-tach.com/cablex.htm
https://www.psiconversion.com/produc...s/ECD-100.html
