12-26-2014, 04:14 PM | #1 |
6 volt pos gr wiring harness
Looking to install a new under dash wiring harness in my 51 ford Victoria. I would like to use a fuse block and due away with the original bullet connectors. I called EZ WIRE but they have nothing for 6 volt positive gr. They referred me to M &H wire but they do not list Ford. Is there someone that sells a universal kit for 6 volt poss. gr. I'm sure this is a common upgrade but I must be looking in the wrong place. I understand the wire size for 6 volt systems is larger than the wire in 12 volt systems?
12-26-2014, 05:18 PM | #2 | |
Re: 6 volt pos gr wiring harness
How many fused circuits do you have in your system? Since you understand that 6 Volt wiring is larger than 12 Volt wiring then unless it is a custom made harness I doubt any of the aftermarket suppliers have anything that is suitable for 6 volt use. Positive or negative ground really isn't part of the equation.
12-26-2014, 05:52 PM | #3 |
I'll bet Tyree Harris could fix you in a minute. Give him a call at 804 556 5200.
12-26-2014, 06:30 PM | #4 |
http://www.vintageford.com/sect_vehi...=Wiring%20Shop
Sacramento Vintage Ford can make it for you, any way you want. Bruce
Works good Lasts long time |
12-26-2014, 07:30 PM | #5 |
There's no connection between my installing a fuse block (fuses are hard to get to where they are now) and getting rid of the bullet connections that seem to be impossible to connect and re-connect. I'm just looking for a way to get rid of the old frayed wiring and make life easier when working under the dash. I know there are fuses for the radio, clock, interior lights, blower motor and others I have not identified yet, be nice to have them in the same place. It would be helpful to know how others have handled this on their Fords.
Thanks --Bill |
12-26-2014, 08:16 PM | #6 |
12-27-2014, 10:35 AM | #7 |
If you are going to modernize all the electrical circuitry, I don't see a point in utilizing 6-volt power. 12-volt is much easier to work with and has a lot of advantages over using 6-volt. One advantage is use of smaller gauge wire to do the same funtions. Where 6-volt needed 16 gauge for a lot of circuits, a 12-volt only needs 18 gauge for the same job.
I don't have problems with the bullets after I figured out how to use a tool to help disconnect them. I'm not a fan of the fabric covered wire either. No matter how good the fabric thread is, the stuff deteriorates at a much faster rate than PVC insulated covering. Rhode Island Wire coats their product with laquer that will preserve it longer but they are more expensive too. |
12-27-2014, 02:32 PM | #8 |
When we install fuses, we construct a board to hold modern push button breakers placed high on the inside of the firewall. Using a circuit diagram, we put the breakers in the lighting circuits and accessory circuits only. You shouldn't fuse the charging system or the horns. If the circuit is open when the vehicle is running, the voltage will spike and damage the generator. As for bullet connectors, we replace them and cover the splice with heat shrink tubing. They were used to aid buildin the car, but are a constant source of problems in cars that are decades old.
12-28-2014, 09:01 AM | #9 |
I as well as others ( I suspect ) know dozens of owners with cars that are decades old with bullet connectors that are not now or ever been a "constant" source of problems.
12-28-2014, 01:42 PM | #10 |
Same subject, different voltage.
I have the same question regarding my '50 shoebox. Harness has many bare wire areas and I would like to go to 12v, central fuse panel, with no junction blocks (front lights, etc.). I know many of these cars have been extensively modified, can't believe there's no one out there supplying harnesses to do this. 6v should be the same with a gauge or so larger wires. |
12-28-2014, 01:48 PM | #11 | |
Should be at least one supplier that makes an upgraded harness for 12 volt use.
