08-15-2016, 07:12 PM | #1 |
What would you do?
Folks on this forum told me that town sedan I now own was made around April of 1931.
It was my dads car and went into storage in 1964. The 1964 Mass registration aligns with the motor number and says it is 1930. - the motor most likely was changed. The motor is in real bad shape and the motor I am putting in is from also 1930. It is easy to register a car in NH so I am thinking that I will use to new motor number and keep the old motor and registration in case I sell the car so someone would have some history if their state is hard butt. What would you do? |
08-15-2016, 08:14 PM | #2 |
Re: What would you do?
My car is in the same situation. '30 motor with '31 body. Sure wish someone would have kept documentation on my vehicle. There's a lot of questions I wish I could know the answer to on its history but not all people think about taking the time for possible future owners. I'm trying to document as much as possible on my restoration for later generations to know the history starting from me. I say you will be doing someone a favor by keeping the motor and papers.
08-16-2016, 12:42 AM | #3 |
Stamp the new motor to match the paperwork.
08-16-2016, 04:56 AM | #4 |
08-16-2016, 06:08 AM | #5 |
What tools/equipment is needed to do this, and where can I get it ?
I will be registering a 31 coupe that has a 30 motor in it as well. Tommy- |
08-16-2016, 06:11 AM | #6 |
08-16-2016, 07:12 AM | #7 | |
08-16-2016, 07:14 AM | #8 |
I would do exactly what you said you are going to do- it is that easy in NH.
nothing wrong with owning a 2nd registration................! |
08-16-2016, 11:35 AM | #9 |
Be sure to check the laws and penalties regarding altering VIN numbers.
Charlie Stephens |
08-16-2016, 11:44 AM | #10 | |
No reason to ever get a DMV/state more involved than they need to be...
1929 Model AA - Need long splash aprons! |
08-16-2016, 11:49 AM | #11 |
You don't even need the restostamps. Just grind off the old number and using 1/4" numbers and a "star" and "A" stamp from Mcmaster Carr you can do it.
You are not hiding anything, you have an original engine for the time period, you have all the paperwork for that number and now you are replacing the engine for the same type and displacement. There is no deceit involved. If you were going to put in a flat head and restamp it with the original number that would be different.
08-16-2016, 01:12 PM | #12 |
The Model A engine IS a flathead.
08-16-2016, 01:21 PM | #13 |
08-16-2016, 02:51 PM | #14 | |
08-16-2016, 03:01 PM | #15 |
No need to grind off anything. Just pull the valve cover and stamp the block to match the current paperwork.
08-16-2016, 03:08 PM | #16 |
Some automobile manufacturers, such as Studebaker, sold replacement engines with bank engine numbers so that the original number could be used. These engines usually had some type of marking to show it was a replacement engine.
08-16-2016, 03:11 PM | #17 |
08-16-2016, 03:34 PM | #18 | |
Thanks Mitch. Tommy- |
08-16-2016, 03:46 PM | #19 |
I bought a set of these stamps here on the SwapMeet:
https://www.fordbarn.com/forum/showth...ghlight=stamps
08-16-2016, 04:19 PM | #20 |
If you restamp your replacement engine, be sure to save the old engine as proof of the provenance of that number. In some states it was common to register a car built from parts of cars with the only number in evidence which, in a Model A, was the engine number.
My 1931 coupe was assembled from junkyard parts back in the 1950's. When the previous owner applied for registration, the Oregon DMV looked up the engine number, which happened to be from 1930, and registered the car as a 1930 vehicle. In 1983 I installed an unstamped Model B engine in the car but have retained the old engine in case anybody asks. At that time I also obtained a metallic tag from the Oregon DMV bearing the number under which the car was registered and the DMV staff glued it to the driver's side motor mount. I doubt that they do that sort of thing anymore!. |
