Old 04-30-2012, 10:06 PM   #1
L78CHEVELLE
L78CHEVELLE's Avatar
Default Book or video how to do valve job 40 Ford
My '40 needs a complete valve job and I have never done one. I have the heads and intake off with the engine still in the car. I can do it if I had a video or book to show me step by step how to do it. Any one know of a video, book, or something that would give me the help I need?
L78CHEVELLE is offline   Reply With Quote
Old 04-30-2012, 10:40 PM   #2
Ronnie
Ronnie's Avatar
Default Re: Book or video how to do valve job 40 Ford
What equipment do you own?
Ronnie is offline   Reply With Quote
Old 04-30-2012, 11:24 PM   #3
Bob G/Spanaway
Bob G/Spanaway's Avatar
Get an old Motor's Manual...they tell what to do step by step.
Library, book store, flea market.
Bob G/Spanaway is offline   Reply With Quote
Old 05-01-2012, 08:24 AM   #4
L78CHEVELLE
I have the sunction cup deal to grind the valves, and I have the long rod coming to remove the guides.
Old 05-01-2012, 08:34 AM   #5
joel
joel's Avatar
The suction cup on a stick is for lapping the valves to the seats after grinding. If you have any erosion,pitting, or deforming of the valve seating surface from long use, your valve seats and valves need to be ground. you might be able to do this in the car, BUT it would be very difficult to keep the grit out of the rest of the engine. I would'nt try it myself.
joel is offline   Reply With Quote
Old 05-01-2012, 09:09 AM   #6
Gumpy
Gumpy's Avatar
Your best bet would be to pull the engine...for easier access....
Gumpy is offline   Reply With Quote
Old 05-01-2012, 09:14 AM   #7
Ronnie
Ronnie's Avatar
It will be a struggle in chassis and hit and miss with split guides and lapping only.
Old 05-01-2012, 10:27 AM   #8
L78CHEVELLE
I have all new valve train items to install back into the engine. I have the one piece guides and the adjustable lifters. I had two exhaust valves that broke off even at the head is why I'm doing this valve job.
Old 05-01-2012, 10:51 AM   #9
Bob C
It's pretty hard to do a good three angle valve job with a suction cup.
Old 05-01-2012, 11:29 AM   #10
4dFord/SC
4dFord/SC's Avatar
Here's one: http://www.ebay.com/itm/Motors-Auto-...r#ht_500wt_954
4dFord/SC is offline   Reply With Quote
Old 05-01-2012, 11:59 AM   #11
ole39
ole39's Avatar
agree on not doing it in the car, been there, done that, never again!
ole39 is offline   Reply With Quote
Old 05-01-2012, 04:11 PM   #12
Karl Wolf
Karl Wolf's Avatar
Where do you live? Might be a good place to start...
I've got the stuff to do it... So do others
Karl
Karl Wolf is offline   Reply With Quote
Old 05-03-2012, 03:45 PM   #13
L78CHEVELLE
Karl, let me say that your offer to help has set me back some. I did not think that people just helped people any more. I live in Kentucky. I have started collecting parts and tools that I think I may need. I have found two manuals in my books that tell me how to do this. With the correct tools I see no reason I can not do this myself with the engine in the car.
Old 05-03-2012, 05:26 PM   #14
Ronnie
Ronnie's Avatar
Lapping stick and compound with new valves is a far stretch for having the correct tools.To do a respectable valve job,you need a valve seat grinding set up for the job. Snap on,Sioux,Kwickway,Black and Decker,Neway.A complete system with the correct pilot for a flathead is what is required as flatties require a 1 1/32" proprietary guide pilot.Just to name a few all can be found on e bay.
Heed some advice and research doing this with more tools to produce a fine job one you will be proud of,done with your hands.
R
