Old 07-20-2015, 02:21 PM   #1
hotrodA
hotrodA's Avatar
Default 32 speedo question
I find the repro face, but understand no one repro's the needle.
Has anyone come up with a substitute that fits the shaft, and is similar in style?
Thanks!
hotrodA is offline   Reply With Quote
Old 07-20-2015, 02:31 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 speedo question
For starters, none of the three manufacturers of '32 speedometers needles are directly interchangeable as the diameter of the shaft and the size of the hole in the base of the needle are not the same. So, I suggest that you supplement your thread by indicating which manufacturer's speedometer you have (Delco, Stewart-Warner, or Waltham).
Old 07-20-2015, 06:16 PM   #3
morrisgauge
Correct. The pointer hub I.D. and shaft length are different for each make. To my knowledge, no one is reproducing that pointer.
www.morrisgauge.com
morrisgauge is offline   Reply With Quote
Old 07-20-2015, 06:58 PM   #4
hotrodA
hotrodA's Avatar
Thanks for the info.
Old 07-21-2015, 12:15 PM   #5
1932BB
P.M. me when you find out which speedometer you have. I may be able to help.
1932BB is offline   Reply With Quote
Old 07-23-2015, 08:24 PM   #6
hotrodA
hotrodA's Avatar
Thank you! I appreciate the help; just now checked the post.
Old 07-25-2015, 09:49 PM   #7
hotrodA
hotrodA's Avatar
It's a Delco. PM sent, thanks, 1932BB.
Anyone else with a needle substitute idea?
