02-09-2012, 11:54 AM | #1 |
Help 34 help
34 guys...have any of you installed window channels? I have a kit for rear quater glass from VINTIQE, I'm totaly baffled how the top two fuzzy rails attach. They are not like original. Kit is USA made and sold through Lebaron Bonney, Macs etc. Im told its the only kit available for 34s . No one at Vintiqe could help! Please let me know if you can help in any way. FRUSTRATED..Ken
02-09-2012, 12:16 PM | #2 |
Re: Help 34 help
Ken , I don't have a 2d to look at but I do have this 34 2d hulk & it looks to me that they slide down & engage the spring at the bottom . Just like doors . Sorry bout not being more help but I'm not into 2d's .
02-09-2012, 12:31 PM | #3 |
Re: Help 34 help
Thanks Dave, that part i get, its the top felt starting at the rear curv and up across the top to front corner that has me baffled. Ken
02-09-2012, 01:17 PM | #4 |
Re: Help 34 help
Here are some pics, the tin piece is original and fits inside at back corner, the two felts would start in it and then follow across the top. the tabs you see by my thumb will not hold the felt securely and there is no provision to hold the remainder of it at top edge after it goes foward beyond tin piece.
02-09-2012, 01:42 PM | #5 |
Re: Help 34 help
Is there a way you can use very small screws to attach it? In the 35 tudor I had I used a Drake kit and it fastened with screws(flat- slot head).It attached same way to on the garnish moulding.
02-09-2012, 02:01 PM | #6 |
Re: Help 34 help
02-09-2012, 02:18 PM | #7 |
Re: Help 34 help
Just looked at the 34 2d hulk again & the fuzzy strip is screwed directly to the body around the window opening . I don't have any 2d rear garnish mouldings but I bet they have screw holes in them . 4d rear 1/4's are like this .
02-09-2012, 04:26 PM | #8 |
Re: Help 34 help
I think I get it now, never thought about puting one on the garnish. Certainly not original but apperantly no one offers original type. My 34 Ford....did you re-use the tin corner piece at inside rear? seems like that could make a difference when its time for upholstery. My 34 Ford..I sent you a PM. Thanks all. Ken
02-09-2012, 05:45 PM | #9 | |
Re: Help 34 help
Ken , This is a 4d rear 1/4 but as you can see it definately is screwed to the garnish .
02-09-2012, 11:53 PM | #10 |
Re: Help 34 help
ken;I used some small black pop rivets.Make sure whatever you use is below the surface of the fuzzy material or you will end up with scratches on your glass. Worked for me Lee34
02-10-2012, 01:00 AM | #11 |
Re: Help 34 help
In the past I have used small counter sunk screws that way they will go below the surface of the fuzzy strips so not to scratch your glass or maybe even break it.
