07-11-2012, 10:07 PM | #1 |
Loud turn signal flasher
I know this has been discussed before, but I can't seem to find it.
Where do I buy a flasher that makes noise? So I remember to turn it off. Thanks Jim |
07-12-2012, 03:47 AM | #2 |
Re: Loud turn signal flasher
Jim;You can get one from RON FRANCIS WIRING 800-292-1940 www.ronfrancis.com Simple hook up.2 wires.Does not even need to be grounded.A little on the loud side.I am sure there are others out there but this works for me.Good luck lee34
07-12-2012, 07:21 AM | #3 |
Mac's has them too. It is loud, I put a little cotton over the buzzer to tone it down.
Bill |
07-12-2012, 09:19 AM | #4 |
I just got one off the rack at AutoZone.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
07-12-2012, 09:34 AM | #5 |
I got mine from Daeco in Stockton, ca 95209,cornerstone cir. It's loud
07-12-2012, 09:52 AM | #6 |
07-12-2012, 10:04 AM | #7 |
Radio Shack has beepers that can be easly wired in and placed where ever you want it. I have mine mounted right above the driver door. Works fine for this pretty deaf flathead driver. I don't remember how much it costs but it was less than $5 They have 2 or 3 different kinds that will work.
~~Walts37~~ |
07-12-2012, 11:28 AM | #8 | |
http://www.radioshack.com/product/in...ductId=2062395
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 07-12-2012 at 11:33 AM. |
07-12-2012, 12:23 PM | #9 |
X two
