03-31-2024, 03:17 AM | #1 |
Waterpumps with smooth pulleys
Somwhere I seen as I thought was 59BA single pulley pumps with steel instead of cast iron.
-What car came this pumps from ? Another question, in that era to 1950 was it only one type of belt or had they wider and narrow ? Read Drake has wider or narrow. Maybe the narrow is a ’modern’ V-belt type. -I ask since I has a clearance issue but my crank pulley is std and so generator pulley. |
03-31-2024, 09:50 AM | #2 |
Re: Waterpumps with smooth pulleys
Hank
Rebuilders may have used steel pulleys. Bruce
Works good Lasts long time |
03-31-2024, 10:17 AM | #3 |
Don’t confuse the 59A stuff with the 8BA stuff (you say “up to 50”). Big changes in 1949, and more variety of pulley, castings, and belts.
03-31-2024, 11:00 AM | #4 |
03-31-2024, 05:40 PM | #5 |
So the truck 48 had the slimmer steel 1 groove ( wide ? ) pulleys.
I try to serach but could not find anything but the pumps I saw is not far away. He said they was rare but consider nice for hotrods. If I bought over e-bay, Hamb or here what to look after to find them. I guess when we talk 48 its wider ( 5/8” or ? ) |
03-31-2024, 06:03 PM | #6 |
https://www.bing.com/search?q=1950+f...ANAB01&PC=HCTS |
04-01-2024, 03:40 PM | #7 |
I have a pair of 37 to 48 Ford script pumps with steel pulleys appear to be original.
04-01-2024, 05:04 PM | #8 |
They may appear to be but they are not. Sometime in the past, those pulleys were replaced. Ford script? Not until 1945 as I recall.
04-02-2024, 01:23 PM | #9 |
Kube,
So what you mean in this ( if steel ) pulleys its not Ford std, do did I get it correct or was they out 45 ? One said truck 47. Last edited by 3W Hank; 04-02-2024 at 04:28 PM. |
04-02-2024, 02:19 PM | #10 |
The "extended" 8RT truck style type pump came up with the '48 F1 series truck. They got the 8BA/8RT in truck speak motors before the cars did in '49.
I believe all trucks were wide belt drives. |
04-02-2024, 04:48 PM | #11 | |
The Ford script pumps didn't happen until 1947. My (initial) memory was incorrect in recalling '45. I had to check my research notes.
04-02-2024, 04:54 PM | #12 | |
To my knowledge and so far I have never seen any tin or steel wide belt pulleys from Ford for this application. Hank if I was doing this I would work with correct parts to accomplish this task. Trying to use the latter magnet with early parts is not very traditional or cool . Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
