Old 02-06-2024, 08:17 PM   #1
millersgarage
millersgarage's Avatar
Default 1965 Thunderbird console texture
I have a 65 t-bird interior in a Kustom. The console appears to be leather covered, but it isn't material, it is like molded with a leather grain type finish.
Any ideas on how to replicate it?
millersgarage is offline   Reply With Quote
Old 02-06-2024, 09:17 PM   #2
Abe Lugo
Default Re: 1965 Thunderbird console texture
Looks up restoring 54-66 Ford Mustang doors, they have a similar wrinkle finish that sounds out too easily.
It might be first you get a type or wrinkle finish paint and then then color you want.
The other way might be to use a vinyl that has a color and texture you want. glue it down.
Abe Lugo is offline   Reply With Quote
Old 02-08-2024, 08:54 PM   #3
JimNNN
I have a '65 T-Bird and I know what you're talking about. When freshening up some interior surfaces I pondered filling in some holes drilled in the lower passenger side dash, which has a similar kind of textured finish. I decided not to do it because it would've been too difficult to match the texture of the filled in holes with the rest of the dash.
My research indicated some people take a mold of the existing texture and use it on the filled surface, but I don't remember the particulars. It seemed like a long shot so I didn't do it.
Two places to investigate further, if you haven't already:
- The VTCI '64-'66 forum.
- Pat Wilson Thunderbird.
Google and you should find both of them.
JimNNN is offline   Reply With Quote
Old 02-08-2024, 09:20 PM   #4
miker98038
miker98038's Avatar
It’s a long reach with an old memory, but I had either a top repair kit or a vinyl seat repair kit that did that. Had something you brushed on a good part and pulled a pattern for the repair area. I don’t recall it working that well, but YRMV.
miker98038 is offline   Reply With Quote
Old 02-16-2024, 05:32 PM   #5
frank long island
frank long island's Avatar
you could try a spray can bed liner will give you texture not sure if its what your looking for
frank long island is offline   Reply With Quote
