Old 10-19-2013, 08:08 PM   #1
Old Henry
Old Henry's Avatar
Default 59A oil leak
My 59A, which was rebuilt 7,000 miles ago, has just sprung some kind of serious oil leak on the front end of it. Front of oil pan is soaked as well as the whole underside and the bottom of everything to the rear of that. It's losing a quart about every 300 miles. (Drove that far on a joy ride today.)
What likely gave way and can it be fixed without removing the engine?
All ideas and suggestions will be appreciated.
Old 10-19-2013, 08:21 PM   #2
41ford1
41ford1's Avatar
Default Re: 59A oil leak
The list of likely causes:
Front seal leak.
Pan gasket leak.
Timing gear cover gasket leak.
Or
Blocked crankcase breather. Could cause oil to be pushed out the road draft.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 10-19-2013, 08:28 PM   #3
37 Coupe
37 Coupe's Avatar
Also check the water pumps if they are the original type that require oil to the bushing. I had a lot of oil leak out of mine after engine rebuild with rebuilt pumps some issue with the oil seal or felt or something,Skip had oil leak issues with this on some pumps but he made it right and I was happy that it was not a front seal and an easy fix
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 10-19-2013, 08:34 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Do you know what type of front crankshaft seal was used during the last rebuild? Two piece rope or a modern one piece lip seal?
John
Old 10-19-2013, 08:35 PM   #5
Kahuna
Kahuna's Avatar
41Ford1 has it covered for you
Kahuna is offline   Reply With Quote
Old 10-19-2013, 08:52 PM   #6
Old Henry
Old Henry's Avatar
Front seal leak.
Pan gasket leak.
Or
All good info.
So, which, if any, can be fixed without removing the engine and which can't?
Old 10-19-2013, 09:05 PM   #7
JM 35 Sedan
Also, It would be helpful to know exactly where that oil is leaking from. Have you tried looking under front of car while the engine is idling? If you decide to do this be careful. I don't mean to insult your intelligence, but it would be best to have the car on level ground, emergency brake on, wheels chocked, etc., while you do this.
Old 10-19-2013, 09:53 PM   #8
Old Henry
Old Henry's Avatar
Good idea. I looked under there the best I could at a gas station on my road trip today but all I could tell is what I've said so far - that the front of the oil pan in soaked and the bottom of everything behind it. I would probably need to get the thing in the air to see more. I'm thinking all I could tell is whether it's coming from the timing cover or where the oil pan is supposed to seal to the block in front. Anything else to look for?
Old 10-19-2013, 11:29 PM   #9
Lanny
Lanny's Avatar
Henry, you can get an oil leak detector additive (oil dye) from NAPA.
Make sure to clean the oil, that has already accumulted, off the engine.
Run the engine with the dye, and use a black light, and the oil leak
can be seen easily, as it shows up as a yellowish colored oil.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 10-20-2013, 12:25 AM   #10
ken ct
Originally Posted by Old Henry View Post
My 59A, which was rebuilt 12,000 miles ago, has just sprung some kind of serious oil leak on the front end of it. Front of oil pan is soaked as well as the whole underside and the bottom of everything to the rear of that. It's losing a quart about every 300 miles. (Drove that far on a joy ride today.)
Boy are you having a run of bad luck. All of the above are possible. Good luck, ken ct.
ken ct is offline   Reply With Quote
Old 10-20-2013, 12:36 AM   #11
Old Henry
Old Henry's Avatar
Thanks for the idea. If I can't see the leak without the dye and black light I'll get it and use it.
Old 10-20-2013, 12:41 AM   #12
Old Henry
Old Henry's Avatar
I guess it kinda goes with the territory when I drive my car as much as I do (1,500 miles in the past week). Won't stop me from drivin' though. I'll just keep dumping the oil in until I decide what to do to fix it. I'm not sure it's much different than when the car was new 65 years ago. It was only guaranteed for 90 days. My last rebuild lasted just slightly more than that. I expect Ford made a lot of money on their repair garages.
Old 10-20-2013, 09:20 AM   #13
moonshine runner
moonshine runner's Avatar
Wow Prof. Henry, I hope you can figure out where it's coming from. As one of the guys mentioned, if possible, wash off the front of the engine, or use Purple Power in a spray bottle (I like this for cleaning my farm tractors when I need to wash off grease), and then it should be easier to tell where your leak is coming from.
Let us know what you find out.
Kevin
moonshine runner is offline   Reply With Quote
Old 10-23-2013, 02:19 PM   #14
Mtn Wudy
Mtn Wudy's Avatar
So,,We are all waiting......
Where is your leak,and have you fixed it ??? We wouldn't want a little oil to "Ground" all your adventures...Signed : Wondering..
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 10-23-2013, 05:04 PM   #15
Old Henry
Old Henry's Avatar
Thanks for your concern. Haven't put it in the air to see where the oil is coming from yet. Got some bigger fish to fry right now. Hope to do it soon. Still drive it daily though. Just watch the oil.
Old 10-23-2013, 06:40 PM   #16
42merc
42merc's Avatar
Also, the distributor hold down bolts could have worked loose. Lots of oil comes out there.
42merc is offline   Reply With Quote
Old 10-23-2013, 07:26 PM   #17
Old Henry
Old Henry's Avatar
Will check that too.
Thanks.
Old 10-23-2013, 07:50 PM   #18
Tinker
Tinker's Avatar
Possibilities have been covered.
On the bright side your chassis is now rust proof!
Old 10-23-2013, 08:12 PM   #19
41ford1
41ford1's Avatar
All good info.
All can be addressed without pulling the engine. You might need to unbolt the front motor mounts and jack up the front of the engine to get the pan off. Only if you need to replace the pan gasket.
Old 10-23-2013, 08:59 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
Seems a bit late for that "rust proof" part, according to this pic that henry posted a while back. DD
Click Links Below __
T5 W/TORQUE TUBE
