05-02-2016, 07:21 PM | #61 | |
Re: High Beams stick on.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-02-2016 at 07:36 PM. |
05-02-2016, 07:39 PM | #62 |
As I look at the buckets closer, it looks like I've got two different kind of buckets. The left one had the conduit but no grommet. The right one had a grommet but no conduit. According to C&G it's one or the other, i.e. the grommet's used when there's no conduit but not if there is. But, the Green Bible shows both. So, I'll get grommets and conduit for both and see how it all fits together.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-02-2016 at 07:45 PM. |
05-02-2016, 07:47 PM | #63 |
None on the car nor in the Green Bible nor sold by anyone.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
05-02-2016, 07:47 PM | #64 |
Ruth Buzzy quote "It's always something!"
05-02-2016, 07:58 PM | #65 |
Also have ordered various lengths and diameters of asphalt wire loom from Sacramento ford... or was it fleabay (cant remember). It's kind of nice to have stuff in stock in the garage. Not real expensive and has a nice authentic look. Sizes big enough to be used to cover welding wire 00 battery cables.
http://www.vintageford.com/sect_sear...tton%20Braided http://www.ebay.com/bhp/cloth-wire-loom Have ordered all the cloth wire harnesses i've ever replaced, with the Sacramento ones. Nice quality stuff. . Last edited by Tinker; 05-02-2016 at 08:27 PM. |
05-02-2016, 08:02 PM | #66 |
128 pc set for $13. Al sorts of different sets. http://www.ebay.com/itm/125pc-Rubber...MAAOSwxp9W4fzS |
05-02-2016, 09:42 PM | #67 |
Don't need a grommet and couldn't install one if I wanted to because the hole in the sheet metal has rounded edges so it won't cut into wire. It also has a clamp right by it to secure the wire so there is no movement that would cause cutting.
05-03-2016, 01:23 PM | #68 | |
But I'll stop bugging you with suggestions. Enjoy your ford craig. |
05-03-2016, 01:44 PM | #69 |
It can sometimes be very difficult to see a huge forest out there, especially if all those trees right in front of ya keep gettin' in the way. DD
05-03-2016, 02:55 PM | #70 |
05-03-2016, 03:29 PM | #71 |
Tinker......I don't believe YOU have ever had a problem seeing around the trees. DD
05-03-2016, 09:14 PM | #72 |
Sorry, I didn't realize this was so important to you. So, I spent some time in Home Depot and Ace Hardware today looking for a grommet that would work but didn't find any. The set you referenced on eBay wouldn't work. They are all for a hole in flat metal, which mine is not. I'll keep looking for some kind that will work. If you find any let me know and I'll buy them and put them on.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-03-2016 at 09:39 PM. |
05-03-2016, 09:27 PM | #73 |
I just looked at 75 grommets of every kind that Mac's sells for all Fords and didn't see any that looked like they'd work for a hole with curved sides like mine.
05-04-2016, 05:43 AM | #74 |
I found a bucket on ebay 141979841793 your looks damaged.
05-04-2016, 05:15 PM | #75 |
Gee wiz....Isn't it amazing that old wire lasted about 69 years in that rounded hole without a rubber grommet, that probably would have dried-up and cracked out by now!! Henry knew what he was doing...
Ed "I find that the harder I work, the more luck I seem to have." - Thomas Jefferson |
05-04-2016, 05:41 PM | #76 |
Both wires going through that hole were covered with a rubber coating that is still like new. One more reason a grommet is not really needed in that hole.
05-04-2016, 06:58 PM | #77 |
Looks like someone had a bad day. Even the best of us have them. Sorry about that. Hope tomorrow's a better one.
I appreciate everyone's suggestions and believe I will get this fixed eventually.
05-04-2016, 07:01 PM | #78 |
That looks like a nice bucket. Thanks for the lead.
05-05-2016, 11:07 AM | #79 |
I really, really don't like stepping here, buuut,,, I see time and again 'your car, do what you will.'--- (NO we can't stand to see anything cut!)--- So here is a one and only user marching to his own drummer, and we can't accept it. Were it a case of no available funding for the project, no one would criticize.
Which brings to mind a question... why would some one want to skin a cat?
Enjoy yer day. Tom Hate can't fix what it started. |
05-05-2016, 11:47 AM | #80 |
I just learned something interesting about the wiring harness that can be bought to replace mine. First, let me say emphatically that I DO intended to replace my wiring harness someday and maybe soon, just not before I leave for Alaska in 5 days. That's a no-brainer that I need to do that. What I learned, however, is that, if I had replaced the main wiring harness for under the dash to the engine compartment as several suggested, it would not have fixed this short problem that I have that turned out to be in the left headlamp bucket. The wiring harnesses do not include the headlight pigtails. I only mention this as a reminder that before we start throwing expensive high labor intensive parts at a problem it is always best to actually accurately locate the problem and diagnose it and a solution addressing that problem. I know some don't like that idea but that's how I try to do things.
