Old 06-25-2019, 06:20 AM   #1
jim1932
jim1932's Avatar
Default 1932 Coupe Battery cable source
I will try to be specific. I have a Model B (4 Cylinder) with the starter pull on the steering column drop. The Battery cables I have are too short. I believe they are for the earlier floor starter switches? I need to go from the Battery to the Starter itself. When I got the car, it came with the battery relocated to the firewall. I am moving it back under the floor as original. I need the part # and a source. Thanks.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 06-25-2019, 07:40 AM   #2
DavidG
DavidG's Avatar
Default Re: 1932 Coupe Battery cable source
BF-14300 (page 6-30 in the book) is approximately 38" long and not that easy to find in original form. (Note that nearly all of the initial B starter motor components carry the BF part number prefix, meaning that they were initially intended for RHD applications.) The B-14551 support strap (page 6-31 and in the drawing below) is even more of a challenge to find, although probably not that difficult to make.
I believe that Rhode Island Wiring offers the cable.
Old 06-25-2019, 09:48 AM   #3
jrhaelig
jrhaelig's Avatar
A top quality 00 cable can be had from Battery Cables USA.
They will create one to your specs and the proprietor is a terrific guy.
https://www.batterycablesusa.com/battery-cables.html
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 06-25-2019, 11:51 AM   #4
jim1932
jim1932's Avatar
David, I am pretty sure I have the support strap. Thanks for the cable info.
Old 06-27-2019, 11:41 AM   #5
jim1932
jim1932's Avatar
BIG improvement....
Old 06-27-2019, 02:41 PM   #6
Pat/Ohio
Pat/Ohio's Avatar
Looks a lot better! Good for you!
Pat
Pat/Ohio is offline   Reply With Quote
