08-24-2015, 09:16 AM | #1 |
overheating and air conditioning
I think my overheating from ac is solved, since I installed the 6 blade fan it seems to run a lot cooler at 85 deg and 70 mph with ac it runs it runs about 180 deg while city driving it stays around 200 deg. I let it idle with ac on it gets up to 210 to 215. this is running water and water wetter. turn off the ac and it will drop.
08-24-2015, 09:25 AM | #2 |
Re: overheating and air conditioning
I went with a temp controlled fan and also had good results. Arizona summers (100+)around town I am running around 215 degrees.
08-24-2015, 09:35 AM | #3 |
I don't have room for a temperature controlled fan, I would love to use one what car do you have it on?
08-24-2015, 10:24 AM | #4 |
I think if you can get a fan with shroud and want it electric controlled it uses a port like heater out let. I tried one most important they go on but nervier shutoff.
Should be able to turn on and off with switch's. I have my fan wired with a light so I know when the fan is on, small light will do. |
08-24-2015, 10:25 AM | #5 |
Do you have any insulation on the firewall, I had a temp control fan but on the highway it would run hot, city it worked great.
08-24-2015, 10:36 AM | #6 |
If you have air you are asking for more troubles if blocking rad. The other day I never see it go to 235 degas 210 is ok. |
08-24-2015, 11:42 AM | #7 |
mine runs 180 185 on road 165 170 in town
08-25-2015, 01:23 AM | #8 |
I was having that problem a month ago but, then i installed a temperature control fan in my Air conditioning unit and now my problem is like gone with more heating.
02-06-2016, 01:29 AM | #9 | |
02-06-2016, 01:39 AM | #10 |
I'm thinking an English Teacher may be able to help.
Alan |
