Old 08-26-2018, 09:12 AM   #1
31pickemup
31pickemup's Avatar
Default 10” clutch issues are driving me nuts!!!! Help!
Hey guys I’m having a hell of a time with my clutch in my 31 coupe. I have a 1941 Ford flathead mated to a 39 toploader. It has a 10” flywheel with all new clutch parts. I’ve had the trans out 4 times now because I can fix this issue. The issue being is the throwout bearing is traveling at least a 3/4” til it hits the fingers and then it’s like hitting a brick wall. The fingers look like they are recessed way to much to the point that they are actually pointing towards the front of the engine instead of sticking back towards the trans. The clutch is a short finger type. Do I need a long finger???I’ve tried two different one of these clutches, both new with the same issue. Please lead me to the right combo!!!!! I have a small video of the bearing moving but it won’t let me post it
File Type: jpg 8DEB0486-202D-458B-AC7D-4D6C1C495DEC.jpg (39.2 KB, 81 views)
Wanted: 1934 Ford original Grille assembly!
31pickemup is offline   Reply With Quote
Old 08-26-2018, 09:15 AM   #2
JSeery
JSeery's Avatar
Default Re: 10” clutch issues are driving me nuts!!!! Help!
Do you have a picture of the pressure plate out of the car?
Old 08-26-2018, 09:20 AM   #3
31pickemup
31pickemup's Avatar
I do not but I will when I pull the trans again. It’s just a stock flat 10” flywheel
Old 08-26-2018, 09:27 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Just a guess, but you could have the wrong flywheel. Also, where did you get your clutch & pressure plate? Pictures of the pp after you pull trans, and pictures of c&pp removed from flywheel. Picture of fork and clutch arm on transmission would also help.
John
Old 08-26-2018, 09:33 AM   #5
deuce_roadster
deuce_roadster's Avatar
Is the flywheel perfectly flat or was it turned so the part where the disk engages a bit higher (thicker)?
Old 08-26-2018, 09:34 AM   #6
31pickemup
31pickemup's Avatar
Perfectly flat
Old 08-26-2018, 09:37 AM   #7
Charlie ny
31,
The clutch does release though...right ? If so you might look into the T/O
bearing carrier. There are a couple different carriers that position the T/O brg
closer to the fingers. The usual prefix 48 part # is most common. Maybe Mac VanPelt
will join in here with pt #'s.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 08-26-2018, 11:04 AM   #8
31pickemup
31pickemup's Avatar
Actually the clutch never moves. Once the throwout bearing moves its 3/4” it stops dead. It’s like the throwout bearing hits a brick wall. Fingers don’t move one bit
QUOTE=Charlie ny;1667571]31,
Charlie ny[/QUOTE]
Old 08-26-2018, 12:06 PM   #9
Brian
Brian's Avatar
It appears that possibly that pressure plate does not have the original, adjustable fingers. Chinese manufacturer?
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 08-26-2018, 12:33 PM   #10
Bored&Stroked
Bored&Stroked's Avatar
Another potential problem is that the clutch disc is the wrong thickness for this particular clutch. If the clutch fingers are over-depressed, that tells me that something is not correctly setup between (or compatible) between the plate and the disc. You might want to contact Ft. Wayne Clutch and Driveline -- they should be able to get you sorted out.
https://fortwayneclutch.com/
Good luck,
D
Old 08-26-2018, 12:52 PM   #11
31pickemup
31pickemup's Avatar
Does it supposed to have the shirt or long finger clutch? I’ve gotten everything from Van Pelt
Old 08-26-2018, 12:57 PM   #12
George/Maine
George/Maine's Avatar
The newer style pressure plates are showing up with that problem.
The new ones have fingers like sliced bread all the same.
You want a 10" like Ford Made. USA.
George/Maine is offline   Reply With Quote
Old 08-26-2018, 01:13 PM   #13
31pickemup
31pickemup's Avatar
Mine doesn’t have those adjuster on the ends.
Old 08-26-2018, 01:29 PM   #14
JSeery
JSeery's Avatar
Have you talked to Mac (VanPelt)? He should be able to assist you if he sold you the parts.
Old 08-26-2018, 01:41 PM   #15
31pickemup
31pickemup's Avatar
Yes and he wasn’t sure what the problem was either
Old 08-26-2018, 02:21 PM   #16
George/Maine
The problem you have can't be fixed.
When you remove the trans measure from flat of bell housing to tip of finger.
With the right old style you will find out the finger with adj screws are 1/4' 3/8' closer the throw out bearing. They are all selling them and will be 1000s out there. sorry junk
Old 08-26-2018, 03:58 PM   #17
Charlie ny
31,
What J Seery said, re-articulate this unfortunate scenario, Mac VanPelt will
reach thru the phone and twist the wrenches !
Charlie ny
Old 08-26-2018, 04:42 PM   #18
51504bat
51504bat's Avatar
Another option is to talk to Ft. Wayne Clutch. They should be able to determine what you need to fix the problem.
Old 08-26-2018, 05:03 PM   #19
deuce_roadster
My vote is incorrect clutch cover. Get one like picture in post #12, make sure disk is in correctly.
Old 08-26-2018, 05:25 PM   #20
Krylon32
Another Vote For Ft. Wayne Clutch. I send all my customers to them. Ask for Leo.
Krylon32 is offline   Reply With Quote
