02-13-2017, 11:03 PM | #21 |
Re: Flathead Engine Balancing-"101"
Gary, I don't see where you have a space for oil on your balance card. As John said Merc cranks can hold as much as 8 grams of oil in the journal. We normally use 6 grams of oil on our balance cards for most all cranks.
02-14-2017, 03:23 AM | #22 |
Jack E/NJ, Like our most learned scribe 'Bored and Stroked' explains here; http://www.jalopyjournal.com/forum/t....862832/page-6
02-14-2017, 07:34 AM | #23 |
Very informative. How is the pressure plate balanced, with or without the flywheel. have one in an engine shop right now to be balanced so I would like to get up to speed. Seems to me they wanted North of $150 to balance the flywheel and pressure plate. Plus $60. to resurface the flywheel. Thank you Fordbarners.
02-14-2017, 08:14 AM | #24 |
one question i had was in relation to a comment that B&S made during his build of the 99 block he has. what are engine builders doing for the floater bearing rods?? do Any of you specifically ask about how they are finishing the ID of the big end of the rod as a bearing surface??
02-14-2017, 08:56 AM | #25 |
Bearing surfaces and honing is a big can of worm to open up...
You should really specify a desired surface finish in Ra....but Ra is an average meaning you can have 9 shallow and 1 to high spot...leading to that you should specify Rk and Rz to. Wow that was a boring hord of symbols..lol Sum is most non flathead shops donīt realise itīs a bearing surface...and how many shops actually has the ability to test the surface... For compairsion a inserted rod needs a Ra of 50-80 but the crankpin bearing needs something in the Ra 10 range. Rz of about 50 for a normal car value goes to half for a performance crank. Im not the best tutor so sorry if your falling asleep. |
02-14-2017, 09:11 AM | #26 |
I guess there are two schools of thought... One, like my father, who believes these engines are just a step above 8 Briggs & Stratton engines cast together. Or, others like B&S & Ronnie the Roadster, who go all out to squeeze every possible ounce of performance out of these beloved engines. That said, my father's stock build flathead has been running well for over 40 years in his '32. As much as he raises an eye brow when I talk about all the things I'd like to do, I'm leaning towards the performance camp in that I want to get all I can out of my motor while having it stay together for a long time. Last edited by Tim Ayers; 02-14-2017 at 10:46 AM. |
02-14-2017, 10:10 AM | #27 | |||||
I do my best to keep ALL this info as accurate as possible, at least with respect to how it's all done here! We CANNOT send a single unit down the road (many out-of-state) and have even as little as a 1% risk of ANY failure/issue. This is the exact reason if I can't dyno any unit I build/assemble here I will not get involved. Just had this scenario up here with another member recently, an earlier "babbitted" unit! (Add) One belief I have here is: "if it ain't broke don't fix it". Thanks, Gary in N.Y. P.S. I know many here won't really believe this but "technically" speaking you CANNOT balance any V-8's, all you can accomplish is making them reasonably "comfortable". Here's where the oil factor comes in, in the larger picture it makes no difference in the longevity OR vibration issue's. This goes directly back to Ron's statement above about changing a set of replacement pistons with different weights than the originals, but using the OEM rods/crank over. For us with 2 balancers we would correct this here, but if not re-balanced it would end up being just fine. You CAN "truly" balance any "opposed" units (Porsche, VW, Corvair, etc.), I believe (not certain) you can also "truly" balance "radial" units?. On most inline 4's and 6's there's no bob-weights required, we do run up these shafts ONLY to make sure they're OK, most are!
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 02-14-2017 at 02:52 PM. Reason: C |
02-14-2017, 10:13 AM | #28 |
It looks like those modern CWT machines take a lot of the guesswork out of the situation. I've never balanced a crankshaft but I used to work on the turbine engines which require balance checks any time the wheels are separated. The old Balreco machine I used back then was all analog with just an IPS meter and a strobe to get the clock angle. Wax was used to get the balance on both ends first then you weigh the wax and remove material from the 180 degree position. It took a while to get good with that machine. A guy had to be careful or you would whittle away too much and have to go back to the other side. Those modern CWT machines look impressive in their adds. They even have the drilling rig right there.
PS: we never got any of them to "0 IPS" (zero imbalance) but we got the close enough and I think better than they were when they came out of the factory in many cases. |
02-14-2017, 07:39 PM | #29 | |
The Stewart-Warner works like you describe above, but we use "clay" on the counter-weights to get it sort of "dialed-in". It does have the meter but this basically tells you where the correction is needed, uses a "strobe" light! This is why I say the CWT really cuts the checking-time way down. We really can't do any strokers on the Stewart-Warner machine (strictly due to the time involved), we did at one time but that went away with the CWT! (Add) On a side note, I put a shot below here of a "real" heavy-metal job on a BBC shaft we converted from a "dependent" to "independent" balance. It takes that many Tungsten plugs to go from a "dependent" OEM 454" damper to the "independent" 427" one! There's a total of 9 plugs (4 in the front/5 in the rear/photo below) in those counter-weights, all measure 1.000" diameter x 1.000" long. Each piece weighs 227 grams and our cost on the plugs alone is over $360.00 without shipping. With that price, the labor to install them, and completing the balance operation, puts a $1000.00+ price tag just for the crank balancing?? Also when installing ANY of these type plugs, they should be put in "horizontally", as seen in the counter-weights, NEVER "vertically"! The "attached" drill press on the CWT is of no value on this type job. This job would be all but impossible to do on the S-W balancer. Thanks, Gary in N.Y. P.S. Also, having that drill press attached directly over the shaft is "a blessing & a curse" at the same time. It can turn into a real headache if you aren't VERY careful. It's very easy to get a "chip" (when drilling) caught between the main saddle and the "shoes". You won't know it even happened until you see the large "scratch" show up on the main journal. I make sure when drilling, BOTH ends of the shaft are covered over, the #1 and #5 mains! Those drilling chips fly around pretty good! It's makes a real "mess" drilling some 1.000" diameter by 1.000"+ deep holes in "4340" steel!
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 02-14-2017 at 07:40 PM. Reason: C |
02-19-2017, 08:41 PM | #30 |
jwl,where are you adding the 8 grams for oil? in the big end weight ?
02-19-2017, 09:45 PM | #31 |
It's a BLACK art!!!
02-20-2017, 06:57 AM | #32 |
Jake, yes.
Perhaps I am more discriminating, than necessary, in my approach to setting things "right" within a engine. But, I don't think so. Even when we get all the characteristics as close as we can it is never "perfect". |
