02-19-2017, 09:39 AM | #1 |
1941 Ford Steering drive
Does anyone know what the connection is at the end of the steering rod as it connect to the steering box? Thanks Jerry
02-19-2017, 09:54 AM | #2 |
Re: 1941 Ford Steering drive
If I understand your question: The steering rod goes from the steering wheel all the way through to the bottom of the box. The only connection is the column tube slips over the top of the gear box and is tightened with a clamp.
02-19-2017, 11:37 AM | #3 |
If your referring to the electrical connection it would be the horn wire.
02-19-2017, 02:09 PM | #4 |
That is the section I am talking about. Could a rag joint be used with another box a 605 or vega power steering box? Thanks Jerry
02-19-2017, 03:34 PM | #5 |
02-20-2017, 11:32 AM | #6 |
