04-27-2011, 05:54 PM | #1 |
Need .874 reamer
I'm rebuilding my clutch and brake pedals and need a .874 reamer to use or rent or buy cheap ( this will be the only time I'll use it ). Thanks to all, Dennis/CT
04-27-2011, 11:11 PM | #2 |
Re: Need .874 reamer
I always felt that buying the right tools for the job was part of the joy of this hobby.
04-28-2011, 03:30 AM | #3 | |
Terry |
04-28-2011, 07:17 AM | #4 |
Have you considered just using a brake hone. Most of these do not require much to be taken out. I have found a brake hone and a couple of minutes you are done. Rod
04-28-2011, 07:21 AM | #5 |
Guesse I had better mention with this method. If you drilled for a grease fitting, make sure to deburr the hole or you will brake the stones. Been there, done that. Rod
04-28-2011, 07:42 AM | #6 |
B.G. |
04-28-2011, 11:20 AM | #7 |
Have you pressed them in yet?
Rarely, but occassionally, bushings are an exact fit after they're installed. Not sure if this was an engineered feature or a reproduction mistake with a happy ending ... but I seem to recall this occuring when I replaced mine ....or maybe it was the clutch fork bushings in the bellhousing? Either way, check em first. |
04-28-2011, 12:22 PM | #8 |
When I did mine this year they were a good fit without the need for fitting them.
04-28-2011, 08:22 PM | #9 |
I did the bushings in my steering box with Brattons stuff and everything fit perfect.
04-28-2011, 11:20 PM | #10 |
I can hone it with a real hone at work for you
pm me if I can help Bill |
