11-18-2013, 09:26 AM | #1 |
1933 Spare Tire Cover
Here's a dumb question, but I'll ask it anyway. On the '33 spare tire cover there is a rubber strip that runs around the perimeter and sits in the channel. Shouldn't that be glued in or some type of adhesive used to prevent it from falling off when trying to wrestle the outer band on?
Also, I have a freshly painted Potter Trunk mounted, and don't want to muck it all up with this tire cover. Wouldn't it be easier to seat the cover on the tire while laying flat on the ground, then attempt to fit the outer band on? Thanks. |
11-18-2013, 12:52 PM | #2 |
Re: 1933 Spare Tire Cover
That rubber strip should be a tight fit and not require glue, but if it isn't a tight fit then glue makes sense. The only spare tire cover that is relatively easy to install is the '36 variety where the whole face plate assembly attached to the spare wheel bracket attached to the body. Otherwise the installation is certainly something of a challenge and yes, the face plate goes first followed by the outer band and if you're doing it yourself, about the only way it can be accomplished is with the wheel laying on a padded surface (not mounted on the bracket).
03-28-2015, 07:30 PM | #3 |
Can those rubber strips be purchased or do you have to make on yourself?
03-28-2015, 08:20 PM | #4 |
Yes, they are normally available from the us (usual suspects).
03-29-2015, 05:47 AM | #5 |
CC33.....when I made my spare wheel cover some 2 decades ago I was unable to find a rubber buffer that was a tight fit and required no adhesive. From memory I bought a rubber strip from Paul Beck, The Complete Automobilist, here in the UK. Doubtless there'll be someone in the US who has something suitable.
Regarding the adhesive.....I found a black rubber compound in a tube, reputedly made from fine rubber granules. Not an impact adhesive... As David accurately states, do not attempt to install the two components with the wheel mounted on the bracket. Whilst the wife is shopping at Walmart, borrow the duvet and lay it on the grass. Fortunately, to date, I have not a had a puncture! "Touch wood" |
03-29-2015, 06:06 AM | #6 |
https://www.trimlok.com/cat/Edge-Tri...ducts_102.aspx |
03-29-2015, 08:34 PM | #7 | |
I ordered one today from Mac's. I will try your assembly technique.. Hope I can find a cushioned place.. If I put the tire on the bed...My wife may kill me! |
