Old 05-22-2010, 08:22 AM   #1
41panelmark
41panelmark's Avatar
Default 40-41 cowl vent question
Does any one have a photo or diagram of the correct placement of the nut/washers on the cowl vent mechanism, 40-41 P/U. I took the vent apart to put in new rubber and I must have gotten the small parts back in incorrectly. The vent will not close tightly nor will it open correctly.
Any help would be appreciated.
41panelmark is offline   Reply With Quote
Old 05-22-2010, 01:08 PM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: 40-41 cowl vent question
I had that problem with mine, but I figured it out. I can take a picture tomorrow if you like.
Cecil/WV is offline   Reply With Quote
Old 05-22-2010, 01:10 PM   #3
John Voelkel
John Voelkel's Avatar
I have a 41 sedan and will check for you. I replaced the seal several years ago
and dont remember any problems.
John
John Voelkel is offline   Reply With Quote
Old 05-22-2010, 01:38 PM   #4
Dennis/Arkansas
Dennis/Arkansas's Avatar
Hey Cecil, I'm in the same situation as Mark. I looked in the shop this AM to see if I could help Mark out. Unfortunately all I have is a disassembled bag of parts. If you would be kind enough to send me a picture as well, I'd appreciate it. Thanking you! Dennis/Arkansas
Dennis/Arkansas is offline   Reply With Quote
Old 05-22-2010, 02:32 PM   #5
Fred A
Fred A's Avatar
Recently replaced the rubber seal in my '47 and found the seal to be too thick, otherwise the shape was correct as purchased from Mac's. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 05-22-2010, 05:36 PM   #6
01aford
01aford's Avatar
I'll email you some pictures. My cowl sel was too thick also. (Carpenter).
Make sure you have the correct hardware. They are shoulder bolts and special washers. I have one set left.
01aford is offline   Reply With Quote
Old 05-22-2010, 08:54 PM   #7
41panelmark
Thanks, the seal is fine but the cover wont come close enough to the closed position, also some times wont open all of the way. I must have the washers on in the wrong positions. Forgot to take photos before I dis-assembled it.
Old 05-23-2010, 10:48 PM   #8
1950effie
This might help you out!
1950effie is offline   Reply With Quote
Old 05-23-2010, 11:29 PM   #9
55 dude
55 dude's Avatar
this place rocks!
55 dude is offline   Reply With Quote
Old 05-24-2010, 07:07 AM   #10
41ford1
41ford1's Avatar
I am attaching some pictures of the cowl vent on my pickup. I hope they show what you need.
41ford1 is offline   Reply With Quote
Old 05-24-2010, 07:55 AM   #11
Cecil/WV
Cecil/WV's Avatar
Originally Posted by 55 dude View Post
this place rocks!
My '40 pickup has the screen on the cowl, not on the vent as shown in this example.
