08-27-2014, 07:20 PM | #1 |
two questions
1 - how much voltage should a 6 volt alternator put to battery = when running lights off and then with lights on - My car is reading 6.9
2 - I notice running at night with lights on- my dash lights dim slightly when pressing on brake - this normal? |
08-27-2014, 11:32 PM | #2 |
Re: two questions
Does the car have an alternator or a generator? If alternator the wiring has been modified to some degree. Is it a (+) or (-) ground system? The voltage to the battery is a little on the low side, should be in the >7.0V range. No, the brakes should not dim the dash lights. What wiring does the car have, original or has it been changed/modified? What size is the wiring to the battery, is it sized for a 6V or a 12V? Are the grounds to the tail lights clean/good connections?
08-28-2014, 05:30 AM | #3 |
Re: two questions
thx - 1 wire alt (disconnected regulator) & new battery - no other changes electrically - all org wiring w pos grd 6 volt - wiring size to battery is correct - car ground are clean
08-28-2014, 07:29 AM | #4 | |
Re: two questions
2 - It's normal for a small drop in voltage when the stop lights are on. This also indicates minimal generator or alternator output. G.M.
www.fordcollector.com |
08-28-2014, 07:59 AM | #5 |
Re: two questions
K thx - It makes me wonder if my alternator belt may need tighting - I didn't want to over tighten for fear of ruining water pumps.
08-28-2014, 08:03 AM | #6 |
Re: two questions
08-28-2014, 08:32 AM | #7 |
Re: two questions
I tighten my belts to a TOTAL movement of 1", this won't hurt the water pumps. If you run a real small pulley on the alternator it requires the belt to be to tight. G.M.
08-28-2014, 08:52 AM | #8 |
Re: two questions
Thanks GM for all the good advise - how do u measure the one inch - just judge by eye?
08-28-2014, 09:13 AM | #9 |
Re: two questions
On a flathead I do not run the one wire alternator. I always run an extra wire from the ignition switch to the alternator regulator(exciter) so it charges as soon as the motor fires up.
08-28-2014, 04:54 PM | #10 |
Re: two questions
The picture shows how to measure. G.M.
