Old 08-13-2011, 02:57 AM   #1
dynaflash_8
dynaflash_8's Avatar
Default Why does my Model A backfire between shifts and after its off?
So iv been driving the heck outta my 30 coupe. Over 300 miles so far in about 2 weeks. One thing i can not get rid of is the pop out the tailpipe between shifts. It doesnt do it when its cold, but after about 10 miles between shifts it has a loud backfire out the tailpipe. Seems to be worse when its retarded, but if i give it full advance, its not so bad. Also, if i drive the car for long distances, when i go to shut it off, it backfires out the tailpipe like a shotgun. This backfire occures 10 seconds after everything in the motor has stopped. Tonight it did this and blew the muffler off the car.
Iv done a full tune up, points rotor the whole bit, and tinkered with the carb, and it will not quit. What the heck is going on???
dynaflash_8 is offline   Reply With Quote
Old 08-13-2011, 03:21 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Why does my Model A backfire between shifts and after its off?
When my car backfired after turning it off, I readjusted the timing in accordance with the procedure posted by Marco and backfiring went away.
http://abarnyard.com/workshop/timing.htm
Old 08-13-2011, 03:44 AM   #3
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
You will get a lot of advice on this one, but here are a couple of things to check.
1. Float level. Turn off the gas valve before shutting down and let it run out of
gas before turning off the switch. if it takes too long to stop, it probably means
that the float is too high.
2. Try driving with spark lever in different positions other than all the way up or
all the way down. You mentioned that it's worse when the lever is up. That is
normal, because you shouldn't be driving with it in the up (retarded) position.
I suggest your timing might be off. Each lever has its own "sweet spot" and you
have to find it. Mine likes it all the way down at highway speeds, and about 3/4
down if I am just crawling along at 10-15 mph. Also, don't forget to make sure
the throttle is all the way up when you shut off the engine. Good luck.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 08-13-2011, 05:36 AM   #4
RonC
RonC's Avatar
You can check your timing by retarding the spark lever, remove the distributor cap and body, turn on the ignition key (make sure your car is in neutral with E-Brake on). Press on the timing pin and slowly crank the engine until the pin sets into the timing gear recess. Do this while watching the points. At the exact moment the timing pin falls into the timing gear recess the points should spark. If not your timing is off. My guess is your timing is late
RonC is offline   Reply With Quote
Old 08-13-2011, 07:37 AM   #5
roccaas
roccaas's Avatar
That shotgun blast 10 seconds after you turn off the engine - bad condenser. Easy and cheap fix.
Do you get popping from the tail pipe when you let off the gas at speed? If so, check your mixture, it is probably a shade too lean.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 08-13-2011, 08:27 AM   #6
Frank Nemo
Frank Nemo's Avatar
When I had the "shotgun blast" after turning off the ignition, I traced the problem to a bad fit between the exhaust manifold and the tailpipe. After tightening that connection I had no more problems.
It does make for an attention grabbing entrance when you arrive at your destination. When I had the Shotgun blast impression, it was time to shout "Shoot him in the pants the coat belongs to me".
Frank Nemo is offline   Reply With Quote
Old 08-13-2011, 08:47 AM   #7
joltesvig
joltesvig's Avatar
I had a backfire issue until I put a brand-new shiney condenser in there...haven't had the problem since...but I still put my fingers in my ears immediately when I shut her down for at least 10 seconds!
Frank, where does that interesting quote come from you shout?
John the Model A Rookie from North Carolina
joltesvig is offline   Reply With Quote
Old 08-13-2011, 01:07 PM   #8
Frank Nemo
Frank Nemo's Avatar
Frank, where does that interesting quote come from you shout?[/QUOTE]
I had an old buddy who would always say "Shoot em in the pants the coat belongs to me" any time he would hear a gun shot sound or back fire. I have no idea where the quote came from, but now that he has passed I always get a smile on my face when I have the occasion to use it and remember his humor.
