12-12-2016, 09:57 PM | #1 |
Just noticed this
I never noticed this in a door wedge before, a piece of felt inside. Would this be for lubrication? Or what?
12-12-2016, 10:03 PM | #2 |
Re: Just noticed this
I've seen a couple like that too, lubrication would be my guess.
12-12-2016, 10:11 PM | #3 |
yes-should be a small oil hole also.
www.whidbeymodelaclub.com |
12-12-2016, 10:17 PM | #4 |
I've seen that on repros. I make my own solid ones.
12-12-2016, 10:26 PM | #5 |
Original Dovetail with oil hole/felt.
12-12-2016, 10:53 PM | #6 |
12-13-2016, 01:32 AM | #7 |
The part is mfgd. By stamping and folding, and after Gary's comment I see mine has two oil holes, one on each side. Unnoticed before.
12-13-2016, 11:09 AM | #8 |
So, what grade of oil and brand is best? What viscosity, would 600 work better? Last but not least: what's the service interval?
12-13-2016, 12:18 PM | #9 |
I use Shell 30w non-detergent for my dovetails. You can get a discount price on it if you buy a 55-gallon barrel directly from your local distributor. I got an additional 10% off for being a senior. Once a year seems adequate. I only use it on my door dovetails, though. I put detergent oil in my engines.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 12-13-2016 at 06:47 PM. |
12-13-2016, 05:44 PM | #10 |
3 in one, i just use reg oil from oil squirt can.
12-13-2016, 05:46 PM | #11 |
oil from top out bottom hole.
12-19-2016, 12:18 PM | #12 | |
12-19-2016, 12:24 PM | #13 |
It should last for the rest of the year, at least.
