03-21-2012, 04:17 AM | #1 |
Please recommend a good 12 volt coil
I have converted to 12 volts and have added an external mounted ballast resistor to my existing coil and it seems to be operating fine.
However, for a "spare" coil, I am considering purchasing a spare 12 volt coil. Could you please recommend a 12 volt coil that I could use? Thank you! |
03-21-2012, 09:48 AM | #2 |
Re: Please recommend a good 12 volt coil
Autozone- LU800 is an internal resistor coil for points ignition
Advanced can cross if you can find a nimrod smart enough! |
03-21-2012, 10:45 AM | #3 |
See my post for additional information about 12V coils.
https://www.fordbarn.com/forum/showth...544#post390544 |
03-21-2012, 10:47 AM | #4 |
II use the Pertronix epoxy filled 3.0 ohm flame thrower coil on my roadster. This is an internaly resisted coil for 12 volt applications. The coil is where the spark comes from and this coil will give electronic or BETTER performance with the original points distributor. The last one that I bought cost around forty dollars. Some of the things that I like about this coil is you get instant starts, the plugs run clean and you can feel the performance boost in the seat of your pants. Another advantage is you get the hot spark of electronic without the module that can and often will give trouble. Here is a picture showing the coil mounted, while I was building up the roadster..
03-21-2012, 11:39 AM | #5 |
Thanks for the replies.
PURDY - Can you please give me a part number and place where I can get the 12v coil you recommend? |
03-21-2012, 01:09 PM | #6 |
If you are interested in souping up the original distributor for hotter spark, I recommend the new points cam from Bill Stipe. This points cam gives an additional 10 degrees of dwell, for even hotter spark. part number SMC 0033 The last that I heard this part sold for $12.75 phone 920-467-2895. More dwell gives the coil more build up times between fireings. I feel that every little bit counts!!!! |
03-21-2012, 03:48 PM | #7 |
e40 coil.. Runs about $18 and requires no resistors.. Bought a bunch of then through Amazon.com of all places.. Shucks/Oreielly(sp) also carry them
